Richard h
- 1,323
Agree with this and sounds like narrowed to shock having something to do with it. Possible shock puts enough tension on pivot points and with out it things are free to move. As for removing quarter panel, sounds like they need to buy the car. Not so sure Ford would support this idea. Convince them it's a safety issue and they'll crush the car.I keep thinking there is a pivot point or suspension link that is causing the clunk. Maybe an oblong hole, defective bushing. I’d be shocked if it was a body issue, but anything is possible.
It would be hard for a dealership to justify, but if it was in my garage I’d probably tear the whole rear suspension out, inspect, see what the bolt & bushing tolerances are. You can tighten a bolt as much as you want but if there is a few thousands slop in the bushing boss, it can cause a clunk as the weight is loaded and unloaded over bumps. Then reassemble to see what happens. Maybe even replace some of the cheaper links on that side.
