- Thread starter
- #1,361
onanysunday
- May 7, 2021
- 3,920
- 3,544
If it ain't steel it ain't real. No body filler in this entire piece. Quite a project.
You're going to fire it up with the trans dry?Used the summit oiler system to pre-oil the engine with 8 quarts of break-in oil. Coolant is all filled up. In the morning I will install the fittings and have the hydraulic system filled up and ready to go for the hydroboost. After 25 months and thousands of hours it looks like we might run this engine tomorrow. I have to wait till the motor is running to pull the side plug off of the automatic transmission. Then I have five quarts ready to go from a pressure cylinder to pump it in. Nice little goodie I found laying around the shop. I will be in the back of the truck right in line of the exhaust trying to reach down and manipulate that plug.
System will hold 12-13 quarts. Right now from bench testing at RPM there is about 5 quarts in the system. Pull the fill plug now and oil runs out. I have to pull the plug in the pan and start putting in fluid right away after it starts and pumps through the trans. Can't check it without the engine running. Fluid level rises with the motor off.You're going to fire it up with the trans dry?
