onanysunday
- May 6, 2021
- 3,969
- 3,580
Wait, no more weld in your own taco kit for the lower arm?
More beef in just the lower arm than previously in the whole setup.
With some changes I now understand what you are saying. LMAO!!!You can see why they had to curl around the boob like that. They’re trying to get the boob axis (imaginary line through the upper boob/lower belly button drawn to the ground) outside the centerline of the boob to limit torque while motorboating. Two ways to do it: like above, or like LSK did with their dual pivot boobs (which adds complexity to gain packaging efficiency). The bonus of Can Am’s setup is the taller the torso, the less leverage the hips have on the upper boob because the distance from the ground to the belly centerline is the lever against the upper boob.
Tire bulges on the bottom, not the top. :biggrin:What happens when you air down the tires???
Might rub on that awkward looking set up...???
:bag:
Yes, but....but...oh dang!Tire bulges on the bottom, not the top. :biggrin:
Flat tires are only flat on the bottom alsoTire bulges on the bottom, not the top. :biggrin:
Crusty, does y0re tire bulge at the bottom when you deflate? :321:Tire bulges on the bottom, not the top. :biggrin:
Fk Robby. You really are a a RG lover.Ok, just to be a pee pee here..... What IF ROBBY had come out with this?????????? 300 pages of "why you use beer cans for suspension parts.....blah, blah, blah......
If RG designed it the Speed fellas would be creaming themselves over such an innovative design.Ok, just to be a pee pee here..... What IF ROBBY had come out with this?????????? 300 pages of "why you use beer cans for suspension parts.....blah, blah, blah......
Yeah, gonna take a bit before paddles catch up. I assume it’s the same brakes for all models, so should be able to run 15s once 6 lug wheels are commonDid anybody notice that the top of the line cars have 16” wheels?
Lol, naw. It would still be 300 pages on how his timelines are unrealistic. :biggrin:Ok, just to be a pee pee here..... What IF ROBBY had come out with this?????????? 300 pages of "why you use beer cans for suspension parts.....blah, blah, blah......
It's easier to get 26" inches of travel when you start with 16" wheels...only 10" to go.Did anybody notice that the top of the line cars have 16” wheels?
That only works in Australia .... :classic_laugh:What happens when you air down the tires???
:bag:
Nope.If RG designed it the Speed fellas would be creaming themselves over such an innovative design.![]()
