- Thread starter
- #1,861
Sand Shark
- 5,271
The X3 was a handful between the shitty power steering and bump steer having the car dart all over the place. First time I drove my first X3 in the desert I was miserable and my arms were tired. LOL! After doing several things I got it under control and it was super stable and fun to drive. Power steering still was not the greatest.In my opinion in driving both, easiest way I can put it, it is easier to drive and steer when you have front steer.
I'm not an expert in vehicle dynamics but driving, especially offroad you can tell the difference.
From RDC:
When turning or cornering say into a berm, when you have rear steer, the tie rod on the outside wheel will be in compression. When front steer it will be under tension.
You will have understeer with front steer on deflection.
You will have oversteer with rear steer on deflection.
In offroad you want understeer on deflection.
When was the last time you saw a TT or Cl1 with rear steer?
It's not a deal breaker whatsoever and it does work, however it is not ideal and makes the car harder to drive. Add in electric power steering and it can be a handful. At least my X3 was at (UTV) high speed in the hardpack.
New X3 is much much better than my old X3. More powerful power steering and they changes the steering rack ratio to make it easier to steer.
