Jersey_Jeff73
- May 6, 2021
- 558
- 404
dam good detective work2024 Sand Scramble what's going on here???? broken exhaust tip with O2 sensor?
Is that RG's car or Max? RG was towing Max and RG's car was popping and spitting like a mother, I wonder if that was the problem? He said that he got bad gas. (Water in it)2024 Sand Scramble what's going on here???? broken exhaust tip with O2 sensor?
Haha, I wonder if that was Robby. He was complaining in the video that his car was running poorly and said he thought it was bad fuel. I bet it was that for sure. I bet the ECU was dumping fuel and making it super rich.2024 Sand Scramble what's going on here???? broken exhaust tip with O2 sensor?
I guess I'll have to go back and look at more pics, but obviously they weren't running the stock exhausts.2024 Sand Scramble what's going on here???? broken exhaust tip with O2 sensor?
I think the latter half of your post is correct. In a tumble like that *something* had to give. I'd rather have the trailing arm tweak than actually bend the chassis.2024 Sand Scramble carnage report from RG & MadMax
https://www.instagram.com/p/C4ovf7JJ-Sj/
I bet they address/tweak the trailing arm design a bit. Maybe not could be a good failure point.
That really does say it all. Granted, people can, and have made RZRs and X3s work very, very, VERY well with their "flawed" suspension design so I'm not saying the Speed setup is the end-all-be-all but at least it delivers on the geometry promises they made.
I agree. Not the test any of us wanted to see... but it does make me feel a little better.Car held up well after that tumble.
See my thoughts above, I agree 1000%. The ECU was like "holy chit this thing is leeeeaaaaaan" since the exhaust/o2 were just floating out in open air.Haha, I wonder if that was Robby. He was complaining in the video that his car was running poorly and said he thought it was bad fuel. I bet it was that for sure. I bet the ECU was dumping fuel and making it super rich.
Got it back 2 weeks ago from Coyne after them having it for almost 3 months. Let’s just say I’m done with Coyne and their service department.Did you get your car back? If so, how is she holding up?
The dude who went on a rant had a similar failure. Not sure if the exhaust is stock with a hacked off muffler, or something completely bespoke.2024 Sand Scramble what's going on here???? broken exhaust tip with O2 sensor?
It’s about compromise.
Most ECUs have some sort of error handling for something like infinity:1 AFRs and default to a safe/limp map.I guess I'll have to go back and look at more pics, but obviously they weren't running the stock exhausts.
However, THIS would absolutely explain why RG's car was running poorly and he thought he had bad fuel vs. Max's. That said, I don't love that these things are "locked" into learning/adaptive mode. Anybody that tunes knows you use learning to get your tune close, then lock it out, tweak it more to your liking and leave learning/adaptive off for *exactly* this reason. Granted, it's probably why my car woke up so much after a few pulls in 3rd (to really load the thing) but if anything fails (o2 sensor itself, wiring to o2, exhaust leak, etc. etc.) your tune will go totally haywire.
-TJ
This is 90% the problem that people have with speed and RG. If he would just simply say the pipe broke off, we would all understand.. This is racing, chit breaks.. but since the beginning, he lies to cover his azz. I truly believe if he was just up front with everybody since the beginning he would have all the support in the world, it would have been a Cinderella storyIt is funny that he got bad gas but max didn't, wouldn't you think they used the same fuel can? It's only 20gl.... between the two cars.
Or, if correction is left on you limit it to 5-10%.Most ECUs have some sort of error handling for something like infinity:1 AFRs and default to a safe/limp map.
But yeah: computer no happy.
Remember, they were on E85... so, all the time? That said, it def seems it was a BS excuse and RG hadn't realized it was his exhaust falling off causing the issue so he pulled that one out of his bag of excuses...When was the last time someone got bad Gas??? Sorry, another poor excuse.
