Fake news and a photoshop job! There is no way the can am could win, Robby told me it was all smoke and mirrors!
Don' say his name 3 times whatever you do...Where is LOTD? I believe he was one of the golden ticket owners that said Speed UTV would never have to issue any Stop Ride notices.
Better they do the recall than have BBQ videos showing up all over the interest or Someone getting hurt or worse - this had to hurt the RG ego - but it must be the suppliers faultTechnically greater than 1% affected, so not that rare in mass-produced vehicle terms…
Don’t tempt me! lLOTDDon' say his name 3 times whatever you do...
My rhino leaked fuel when the carb got jacked up. It never went fast enough that would could not jump, tuck, and roll.What is it with Fuel Pressure issues on SxS's? Bummer it happened to RG, but it's not a surprise.
Fix it and move on.
I have not had an OHV, ATC, ATV, etc that did not at some point leak fuel on the motor. The difference it on a small ATV, etc. you see catch the issue quickly vs drive for miles until you become a ball of flames.
Scratch that...the Rhino never leaked any fuel, but sitting in the garage it was less likely anyways :lmao:
Isn't that how you're supposed to drive it?Standard stuff? I didn't circle that, I took this from a post. It certainly looks like if you touch that car you're warranty is over
6. Damage caused by pinging? What if an injector half-died? Damage caused by dirt ingestion? What if the stock air filter died, or the hose clamps weren't tight?Standard stuff? I didn't circle that, I took this from a post. It certainly looks like if you touch that car you're warranty is over
You need to realize that by doing this / SPEED makes a lot more $$$$ and can avoid those pesky warranty claims....Everyone knows that the stuff that is made aftermarket is NEVER as good as the manufactures design.Not sure how standard this is, but man, you can drive a truck through the door opened by these exclusions.
I am pretty sure that is standard language in all OEM warranties. Just sounds worse when you think of all the RG sales pitches he made in all those infomercials.Standard stuff? I didn't circle that, I took this from a post. It certainly looks like if you touch that car you're warranty is over
Seems those pitches kind of override the warranty here, no?I am pretty sure that is standard language in all OEM warranties. Just sounds worse when you think of all the RG sales pitches he made in all those infomercials.
To be fair, that line says High Engine RBM's, not speeds.Shifting at High-Speed operation was one of the selling points or not? The prohibitions seem "Excessive"
Seems he is really good and getting patents and voiding a warrenty....in his favor.
Every sequential I’ve ever driven was 7,999rpm (1rpm shy of the limiter), then mean it when you shifted (nothing slow or it made bad noises) with a slight lift. Opposite on downshifts (slight stab of the throttle to match RPM).To be fair, that line says High Engine RBM's, not speeds.
I don't think you shift any sequential trans at High RPM's, you gotta let off the throttle to shift.
