Paully
- Oct 6, 2022
- 61
- 101
Glad to see he doesn't chit talk about other manufactures.
I will bet you the cage holds up fine. You wade up any car at 70+ it ain’t going to feel good.The roll cage terminates to no where, it’s hidden by the plastics as you can see on the other side. There are pop rivets next to welds. There is a metal stiffener on the a arms to add extra thickness but it’s folded over on itself and welded in place. Why not just make them with thicker material to support the loads instead of what they did?
Bashing Robby isn’t the point, there is no way in hell that cage holds up when you endo at the speeds that car is capable of. It’s got an awesome power train but I wouldn’t be in it unless you spent thousands on necessary upgrades to hold it together.
I sure hope so but it didn’t look like it. Even the view from underneath on the plastic side showed the cage terminating to no where.
just to change things up, who’s ready for Glamis? First trip in less than five week
Okay. Are you an engineer by chance?The roll cage terminates to no where, it’s hidden by the plastics as you can see on the other side. There are pop rivets next to welds. There is a metal stiffener on the a arms to add extra thickness but it’s folded over on itself and welded in place. Why not just make them with thicker material to support the loads instead of what they did?
optical illusionI sure hope so but it didn’t look like it. Even the view from underneath on the plastic side showed the cage terminating to no where.
just to change things up, who’s ready for Glamis? First trip in less than five weeks
and everyone is touching your car hahahHad a good time at the show today. It was huge and packed. Only lasted about 3 hours.
just like in the past, people are morons and need to finger eff everything.
saw Shawn at Gibson. Been many years and he’s the same go fast guy.
ridered and family!
sandtrap tO close out the day.
7 hours of driving for 3 hours of show. Probably not again but got what I wanted.
Yep.What SXS are you getting for the season? You driving the Honda Talon?
The El Diablo and Bandit are pretty cool.
Lots of customer cars in the booth. Some had some cool wraps.
You can buy that jack from Speed that lifts up the Diablo for $2500.
pretty close on aliababa for only 250.00 lmfaoThe El Diablo and Bandit are pretty cool.
The X3 had the same thing. That tube has never done anything. Only difference is apparently they don’t bolt it to anything.Checked out the CanAm dead tube situation for myself. Ho Lee Fuk. You can reach under the fender and feel the tube. Connected to nothing, and open ended. They didn't even weld a cap on the end.
