Rockwood
- 8,464
From the video.
Scrub radius: exactly centered isn’t a good thing. Slight offset inside or outside (depending on rear or front steer) helps for more positive and stable steering feel. You don’t want a lot, but you want some or you end up with some oscillation in the tire tread as it encounters imperfections in terrain and the steering has a wandering/uncertain feel. Either way, I don’t think homeboy’s wheel/tire package is stock, so not sure why they’re comparing scrub radius there.
Longer arms on the Speed will be nice. I don’t think there’s a huge strength advantage in heims (“monoballs”) on the ends of control arms compared to ball joints. Stronger? Sure, since the heim’s shank is physically larger. But it’s still a compromised design since it still has the threaded shank of the heim as a weak point. No trophy truck uses heims there.
$7-800/arm for boxed arms? Can’t you get a complete set with uniballs for like $2k?
Overall CoG looks a lot better.
Visibility: I highly doubt the 1’ closer FOV matters at all. Other than rock crawling, if you’re looking 10’ away at the ground, you’re gonna die. In the rocks, that 1’ of extra memory won’t matter. Cool they looked at it, but meh.
Interior looks clean. Digital dash on the Speed is cool. Glare might be an issue, but lots of function there. Anyone know if it’s waterproof?
Roll centers: we’ve killed that discussion. He does say his outer pivot is lower when measuring ground clearance, then says the inner is lower. On the Polaris, the wheel can’t tuck under the vehicle unless it’s broken. When cornering with enough force to roll a vehicle, you won’t have the outer suspension unloaded like that anyway.
Not sure how semi trailing arm is a decade ahead of multi link, but okay.
Negative camber at full droop is good? With body roll, the contact patch on the unloaded tire (drooped) would be smaller and it would be harder on CVs.
He forgot some measurements:
Engine displacement :bag:
Suspension travel
Bumpsteer
Live valve?
In the end, this looks orchestrated to show where his is bigger. The existing marks where they measured things out reminds me of movies where you can see the previous take’s skid marks on the road. Color me surprised.
Suspension travel
Bumpsteer
Live valve?
