- Thread starter
- #3,201
Sand Shark
- 5,366
The Walker Evans Velocity shock is a pretty decent shock. That is what Polaris is using on the non-live valve models. Once enough of the Pro R and Turbo R cars are out I am sure both Fox and Walker will offer a fancy billet clevis. When I was talking to the Polaris people when I was checking out the Pro R they said they had to go with a beefier front diff. They tried using the Turbo front diff and it would not hold up during testing.Yep. The length of the tabs is problematic but not hard to deal with. I'd guess the coil bucket sitting directly on the clevis mitigates some (salty desert mud + aluminum + steel anyone? :biggrin: ), combined with the overall beef/material choice compared to welded on tabs. Looking at photos, I'm assuming forged steel since it's painted. Polaris isn't really prone to chassis failure as a company (Can Am is much "better" at that), just shitty shock choices (Walker Evans pretzels anyone?) and of course the ever-present lack of ability to address car-b-ques.
But no, you can't just throw some 1/4" mild steel at it like you would tabs on a control arm, but not that different than the extended shock ends you see on some desert racers:
Hell, Fox will sell you this thing for their big boy shocks:
https://www.kartek.com/parts/fox-3-coil-over-or-35-4-44-bypass-shock-bottom-eyelet-56-top-edge-to-cntr-use-34-uniball.html
My guess is they'll all burn to the ground or assplode diffs/gearboxes before that clevis fails in regular use. :biggrin:
Fabwerx uses an extended eyelet for his trailing arms for the X3.
