- Thread starter
- #2,081
Sand Shark
- 5,323
Are you facking with me? is one of my favorite lines ever :biggrin:That movie is underrated.
Damn you!! now I want to watch this movie again!!!!Are you facking with me? is one of my favorite lines ever :biggrin:
#metooAre you facking with me? is one of my favorite lines ever :biggrin:
Thanks to this thread I watched it last night for the 1st time. Good movie.Damn you!! now I want to watch this movie again!!!!
I watched the other night. LolThanks to this thread I watched it last night for the 1st time. Good movie.
RG spoke a bit about it, and unsurprisingly the CVT seems to be part of the issue. The trans is a dog-box, which generally is more suitable for clutch-less shifting but still needs torque to be reduced for a shift and requires better matching engine speed to the next gear (up or down) than a synchro (as in, synchronizer) trans. My ASSumption is that the CVT causes load to still be put into the trans input shaft because of all the momentum of the secondary bolted to it. There's also probably a longer lag from throttle-lift to load being reduced in the trans as the clutches have to do their thing... and they're not really designed to fully remove load. So it's probably an issue where you lift throttle, but the clutches are still imparting load in the trans so you can't shift, by the time the clutches reduce load into the trans enough to allow the shift now the motor has slowed down way more than you'd want (I'm talking upshifts here) and it's not a clean shift. Going for a downshift seems even more problematic, you lift and wait for the whole load reduction song 'n dance, then try to blip the throttle to let it slip into the next gear but the CVT is going to back-shift and hit the trans with load because of the throttle blip rather than just a light spin-up to help match the input shaft speed to the required rpm to be in the next lower gear at the given vehicle speed.I'd be interested in the shift on the fly idea, and how it now sounds like you have to be capable of shifting a Roadranger to make it happen. Didn't sound that way at the outset.
Also my ASS-umption. Just interesting to get an insight into whether they had not anticipated something that seems rather obvious, or if something else is at play.RG spoke a bit about it, and unsurprisingly the CVT seems to be part of the issue. The trans is a dog-box, which generally is more suitable for clutch-less shifting but still needs torque to be reduced for a shift and requires better matching engine speed to the next gear (up or down) than a synchro (as in, synchronizer) trans. My ASSumption is that the CVT causes load to still be put into the trans input shaft because of all the momentum of the secondary bolted to it. There's also probably a longer lag from throttle-lift to load being reduced in the trans as the clutches have to do their thing... and they're not really designed to fully remove load. So it's probably an issue where you lift throttle, but the clutches are still imparting load in the trans so you can't shift, by the time the clutches reduce load into the trans enough to allow the shift now the motor has slowed down way more than you'd want (I'm talking upshifts here) and it's not a clean shift. Going for a downshift seems even more problematic, you lift and wait for the whole load reduction song 'n dance, then try to blip the throttle to let it slip into the next gear but the CVT is going to back-shift and hit the trans with load because of the throttle blip rather than just a light spin-up to help match the input shaft speed to the required rpm to be in the next lower gear at the given vehicle speed.
-TJ
FBW right? Seems they could rev-match it to expected RPM like most MT cars do today with auto rev-matching. Mapping would be a little more complex given CVT, but doable.RG spoke a bit about it, and unsurprisingly the CVT seems to be part of the issue. The trans is a dog-box, which generally is more suitable for clutch-less shifting but still needs torque to be reduced for a shift and requires better matching engine speed to the next gear (up or down) than a synchro (as in, synchronizer) trans. My ASSumption is that the CVT causes load to still be put into the trans input shaft because of all the momentum of the secondary bolted to it. There's also probably a longer lag from throttle-lift to load being reduced in the trans as the clutches have to do their thing... and they're not really designed to fully remove load. So it's probably an issue where you lift throttle, but the clutches are still imparting load in the trans so you can't shift, by the time the clutches reduce load into the trans enough to allow the shift now the motor has slowed down way more than you'd want (I'm talking upshifts here) and it's not a clean shift. Going for a downshift seems even more problematic, you lift and wait for the whole load reduction song 'n dance, then try to blip the throttle to let it slip into the next gear but the CVT is going to back-shift and hit the trans with load because of the throttle blip rather than just a light spin-up to help match the input shaft speed to the required rpm to be in the next lower gear at the given vehicle speed.
-TJ
FJB?FBW right? Seems they could rev-match it to expected RPM like most MT cars do today with auto rev-matching. Mapping would be a little more complex given CVT, but doable.
Yeah, I just have to give Rockwood a hard time. As for the actual answer, to be honest I don't remember but I would ASSume so...FBW = Fly by Wire (no physical throttle cable)
