- Thread starter
- #681
ChEFF
- 11,099
37k for the driveway? jesus I didn't realize its that expensiveBack to the TOPic chEFF. Driveway poured and in the cure process. 7 days STAY OFF............water twice a day to help. The design process was pretty cool. Brought the motorhome over and pre ran the driveway. Back a trailer in. Pull straight in. Pull past the house and back in. Used every scenario. Painted it out and that's what I came up with. Pretty Cool. YES..................Expensive. $37k and change. Once it's cured.............then I'll get to hang these garage doors I've had since November. Wait til you see these BAD DUDES! Peace
So does that spray septic water on the track? Man that’s going to be a shiaty section.
Cut and splice where the wire comes out of the wall ChEFF. Instead of replacing an eye and wiring that was damaged from the sun, that's what I did. Butt connectors work just fine unless you want to get fancy and solder it with shrink wrap.Installed a couple garage doors yesterday. One of the pre wired photo eye wire was dead. Door will not operate. And the wire is inside the wall already spray foamed. How is the electrician going to run another wire? Going to suck to have to run a wire old school way......stapled to the ceiling! Peace
