Off season remodel and prep
Well gentlemen here we go again.
Last trip of the season didn't go as well as one would hope. After about a week of heavy winds the dunes were absolutely perfect and un touched. But with that comes some dangers that require a higher level of attention. Well one of those dangers got us. While cruising around at a moderate pace we came to a seemingly smooth bowl transition that turned out to be a sheer drop nothing super crazy and the car soaked it up well but it was enough to slap the ass of the car down onto a little hump in the dune which wound up bending the removable engine cage section (as seen in the pictures below) luckily it was easily repairable by swapping out the top tube. Another thing I wanted to accomplish in this off season was redoing the dash and console. so i rearranged the gauges, upgraded the GPS, and added a switch pro to modernize the wiring in the car. the dash and console came out amazing wrapped in vinyl to match the new seats.
while doing a thorough inspection I found some stress cracks in a couple support tube connections around the transaxle so instead of doing the repair and touching up the paint which looks terrible on a white car i decided to tear it down completely and start the process over again. I have made a new list of things i wanted to adjust as well so those will get done while the car is down. the new list is as follows.
1.new front seat mounts. for adjustability these are a 2 piece design so angles and locations can be configured how ever the driver desires. somewhat futureproofing this thing.
2. new radius windshield. new tabs would need to be welded to frame.
3. adding a few gussets around the back half
4. tie in front bulk head to bottom of chassis better spreading the load. this isn't a major issue but in my experience it could be stronger.
5. relocating transmission rear mount from closest to the bell housing to the opposite side of the mount this way the gearbox will be much easier to remove for services. the gearbox is currently wedged between the front and rear mount and there is very little room to pull this thing out without damaging the coating.
Good day gentlemen! Have been making little progress on the car since its been so hot but I have time.
a few updates
1. relocated the rear gearbox mount to in front of the bell housing mount and boxed it in
2. added a gusset plate and boxed in the front end to tie the bulk head into the chassis a little further. and added a couple fish plates
3. removed all of the old front seat mounts and designed a much more universal setup this can be adjusted up to 4.5" forward using the same seat plate and if i need any thing different all i need to do is cut out some adjusted seat plates without having to cut into the car again.
4. added a few small plate gussets around the gear box area.
5. replaced the bent upper part of the removable engine cage.
6. and ground out and cleaned up a couple more welds that i wasn't happy with.
7. removed and adjusted the turning brake mount as well it was too close to the seat.
8. I forgot i also deleted the light bar tabs on the roof. this makes the car look so much cleaner. ill likely create some bolt on aluminum brackets to put the light bar on if i choose. I hardly ran the bar anyway with the windshield
Next, it goes to a local tin guy to get a radius windshield frame made. and i have parts on order for the rear sway bar addition.
then powder again and reassembly.
I like all of your improvements and the work looks top notch.
But I was hoping that you might add some doors so I could copy them 😆.
Nic work ! Love the way you did the seat tabs and Sliders - Also- That Dash ROCKS soo simple!
Thank you sir. Doors are nice but ill save that for the side by side crowd HAHA
  • Like
Reactions: FOG
Thank you im very happy with how the dash and console came out as well i cant wait to see them in the car with the rest of the interior in place.
Hey all I have a small update for you.
New additions
1. an adjustable clutch pedal stop
2. couple little pointy doodads to the front bumper
3. boxed nerf bar supports
4. new harness bar since the seats moved back slightly the old one was in the way
she is off to get the windshield frame made this week. then it comes back for final QC and off to powder coat
Shes off to Kurtco in phoenix for the windshield frame.
Hey all, while the car is at the fabricator for the windshield frame and all the arms are at powdercoat i decided to prep the outboard hubs and cvs as well as make some new boot bearing retainers the ones on the car now are goofy since they were made from delrin bushings modified to hold the bearing so they allowed some sand to get by this should fix that problem. The new retainers will be made from aluminum and have some o ring seals on the id to allow the retainer to slide a little on the axle as well as keep out the sand.
Small update, I got the car back from Kurtis @kurtco_specialties (Instagram) in Glendale AZ and he did a killer job on this windshield frame and was very communicative and reasonably priced definitely recommend this dude.
I snapped the glass cutting it so i have another one on order along with the lock seal gasket.
All that's left on the list of junk before it goes to powder
changing out the A+ pillars to 1.5" tube and connecting them to the top bar correctly
adding some tube support around the bottom of the engine. check out the MS paint example. The engine cage as you can see in the last image doesn't provide any real protection to the motor or structural support to the back of the car. I'm afraid if this thing did a big uncontrolled ass slapper wheelie that I would wind up with the same problem as before with the bent back half. It seems that more and more of the newer cars are going with a completely welded back half and more support around this area so what's a few more tubes.
This thing is never going to get finished if I sit around and stare at it. another addition completed. All that is left is the A+ pillars and she's off to powder.
Good Morning Gents all fabrication on the car is complete and shes finally ready to go to powder this week. I will be doing white again but this time it will be the correct white. The powder coater i used last time assured me that the color they were using was the same color as the body panels WH04 but it was off just enough to bother the hell out of me.
the rear engine cage area is completely welded out and I replaced the A+ pillars with 1.5" tube and moved the top back to inline with the eyebrow tube across the windshield those things made the car look quite a bit beefier alone. check previous pictures for the before.
I also attempted to cut the glass for the windshield but have had no luck i have the technique down but the glass i chose to use out of a second gen Tacoma has a gnarly "cup" on the sides that has put up a fight I'm 5 windshields in and they 6th times the charm.
Now hurry up and finish it so we can get some time in the sand
I have a small update. While the frame and new windshield frame are at the powder coater i figured i would start prepping some parts and painting the bypasses.
i also received my axle boot bearing retainer deals and they came out sweet.
For the shocks i decided to try out Alloy Armor and man i cant say enough good stuff about this product so far. We will see how well it holds up on the car but damn this stuff sprays nice, lays super smooth and looks amazing.
I should get the frame back later this week or early next week so stay tuned for the reassembly progress.
Where can I get a set of those retainers?
i designed these and sent them to a local machine shop that owed me a favor. they quoted me $400. other wise i would have used parts badger. this is the quote from them
do you have the bearings already?
