Off season remodel and prep
Well gentlemen here we go again.
Last trip of the season didn't go as well as one would hope. After about a week of heavy winds the dunes were absolutely perfect and un touched. But with that comes some dangers that require a higher level of attention. Well one of those dangers got us. While cruising around at a moderate pace we came to a seemingly smooth bowl transition that turned out to be a sheer drop nothing super crazy and the car soaked it up well but it was enough to slap the ass of the car down onto a little hump in the dune which wound up bending the removable engine cage section (as seen in the pictures below) luckily it was easily repairable by swapping out the top tube. Another thing I wanted to accomplish in this off season was redoing the dash and console. so i rearranged the gauges, upgraded the GPS, and added a switch pro to modernize the wiring in the car. the dash and console came out amazing wrapped in vinyl to match the new seats.
while doing a thorough inspection I found some stress cracks in a couple support tube connections around the transaxle so instead of doing the repair and touching up the paint which looks terrible on a white car i decided to tear it down completely and start the process over again. I have made a new list of things i wanted to adjust as well so those will get done while the car is down. the new list is as follows.
1.new front seat mounts. for adjustability these are a 2 piece design so angles and locations can be configured how ever the driver desires. somewhat futureproofing this thing.
2. new radius windshield. new tabs would need to be welded to frame.
3. adding a few gussets around the back half
4. tie in front bulk head to bottom of chassis better spreading the load. this isn't a major issue but in my experience it could be stronger.
5. relocating transmission rear mount from closest to the bell housing to the opposite side of the mount this way the gearbox will be much easier to remove for services. the gearbox is currently wedged between the front and rear mount and there is very little room to pull this thing out without damaging the coating.
Good day gentlemen! Have been making little progress on the car since its been so hot but I have time.
a few updates
1. relocated the rear gearbox mount to in front of the bell housing mount and boxed it in
2. added a gusset plate and boxed in the front end to tie the bulk head into the chassis a little further. and added a couple fish plates
3. removed all of the old front seat mounts and designed a much more universal setup this can be adjusted up to 4.5" forward using the same seat plate and if i need any thing different all i need to do is cut out some adjusted seat plates without having to cut into the car again.
4. added a few small plate gussets around the gear box area.
5. replaced the bent upper part of the removable engine cage.
6. and ground out and cleaned up a couple more welds that i wasn't happy with.
7. removed and adjusted the turning brake mount as well it was too close to the seat.
8. I forgot i also deleted the light bar tabs on the roof. this makes the car look so much cleaner. ill likely create some bolt on aluminum brackets to put the light bar on if i choose. I hardly ran the bar anyway with the windshield
Next, it goes to a local tin guy to get a radius windshield frame made. and i have parts on order for the rear sway bar addition.
then powder again and reassembly.
I like all of your improvements and the work looks top notch.
But I was hoping that you might add some doors so I could copy them 😆.
Nic work ! Love the way you did the seat tabs and Sliders - Also- That Dash ROCKS soo simple!
Thank you sir. Doors are nice but ill save that for the side by side crowd HAHA
  • Like
Reactions: FOG
Thank you im very happy with how the dash and console came out as well i cant wait to see them in the car with the rest of the interior in place.
