- Thread starter
- #121
Rockwood
- 8,412
You're spot on.Based on your experience of when the noise occurs, what do you think is causing it? A shock mount? A brace, or bushing?
I'm just thinking, the Ford engineer may or may not be the brightest bulb in the chandelier, or he may just be suffering from too much "in the box" thinking - ie. the solution is a factory part, but what if the upper shock mount threaded portion is just a touch too long and even though it's torqued to spec., it's still allowing enough slop in the bushings to make a clunking noise as it loads/unloads. That's just a "what if" - I have no idea what the shock mount looks like, but if there's a little slop somewhere and the addition of a couple of washers not in the drawings can take out the slop and clunk - problem solved by you, probably quite a bit sharper at problem solving than he is.
For yrs my GT was having alternator overheating problems until I was told by a retail parts guy that the factory connector was too short, causing all of the overheating and fires. Once he gave me the longer connector, the problem was solved permanently. But the factory engineers are the ones who selected a connector that was 1/4" too short and barely made contact.
If it were me, I'd get whatever written/monetary concessions I could get out of them, then T/S and fix it myself. Hell, if it turns out to be 2 washers fixes it, market it as the "rear suspension repair kit" and sell it on Ebay for $25 a pop!
:thumb:
OEM rear mount. Note the height of the stock isolator compared to the depth of its spot on the mount. The rubber has some protrusions on either side, but there's a lot of void space in there. I'll see if I can play with washers to take up some slack yet still maintain articulation (the control arm's arc doesn't require much in the way of articulation, so this should be easy). The void space plus that bearing are probably what I'm hearing.
If I can't fix it, I'll just get an aftermarket mount and be done with it. Hell, I might anyway since the slop in the stock mount causes an annoying undamped bounce while the shock overpowers the slop in the mount, so most swap them out anyway. What I get for not joining the forum on the car I like like I usually do.
See above :biggrin:is there a tower support you can add to help with the deflection or whatever is moving? We use to do that in the Accord sedan's to help stiffen the roll on the car. Something like this? https://www.bmrsuspension.com/?page=products&vehicleid=24&maincatid=117&catid=499
