Arch Stanton
- May 6, 2021
- 102
- 137
Best thing to do is remove baffles.Word of caution with powder coating the valve covers. They like to hold a lot of the sand from the sandblaster in the baffles underneath. Seen that happen more than once.
Yes, try Scotts Honda Salvage in Fort Collins Co.Anyone have a spare crank sensor laying around? Mine broke last night and dealer wants $380. Asking here before hitting the junkyard
There are 8 or so codes that just remain always. Never seemed to be an issue.Guys i need to buy a obd2 reader to erase my codes. Which one yall got and what app?
I was thinking of switching my J35 to the throttle bracket on this page.So I ass-u-me there are actually 4 places the coolant by-pass needs to be capped when doing the intake flip. Please correct me if I'm wrong on these locations. I should be capping locations 1 & 2 in both of these pictures, right?
On another note the second picture also shows what I came up with for a throttle cable bracket now that the throttle in at the rear of the buggy.
That is the one in the photo of my motor. Got complete setup with cable mount included.I was thinking of switching my J35 to the throttle bracket on this page.
https://www.arizonaperformanceimports.com/parts.html
Does that throttle arm work better or smoother than the oem setup?That is the one in the photo of my motor. Got complete setup with cable mount included.
Yes! Well worth the change. I used it on all the motors I did.Does that throttle arm work better or smoother than the oem setup?
I could not tell from the pictures on the API website where the lower bolt was attached, so thank you for the better quality picture. I went ahead and designed my own since I had those two bolt holes in the vicinity. It looks like that API bracket will only work for intakes that have not been flipped. I don't know what was originally mounted to those two holes on my J35, maybe a power steering pump??That is the one in the photo of my motor. Got complete setup with cable mount included.
Since it mounts to the throttle body, I think it will work on a turned manifold as well.I could not tell from the pictures on the API website where the lower bolt was attached, so thank you for the better quality picture. I went ahead and designed my own since I had those two bolt holes in the vicinity. It looks like that API bracket will only work for intakes that have not been flipped. I don't know what was originally mounted to those two holes on my J35, maybe a power steering pump??
When I get time I can design and cut another flipped bracket that uses the simpler two bolt clamp for the push pull cable.
I suppose, but I think without a lower mounting point in addition to those two small bolts on the throttle body, I would be worried they would wiggle loose/strip out with that long of a moment arm acting on them. I like mine better. :classic_biggrin:Since it mounts to the throttle body, I think it will work on a turned manifold as well.
No, very solid. It is mounted as designed, to tb only.I suppose, but I think without a lower mounting point in addition to those two small bolts on the throttle body, I would be worried they would wiggle loose/strip out with that long of a moment arm acting on them. I like mine better. :classic_biggrin:
Thanks! I think I'll order that setup.Yes! Well worth the change. I used it on all the motors I did.
OK good. Looking closer now I see that lower third bolt is at the throttle body also. I thought it was tying into some other location that is only on that side of the engine. So is one or both of the throttle body springs removed? Can you get a picture of that connection from the top when you get a chance? My throttle body has a ball stud welded onto the stock outer plate, but it looks like yours is cleaned up some with that bracket & new plate/ball stud. Thanks.No, very solid. It is mounted as designed, to tb only.
Where do these plug in to? Can they just be capped off?These two guys will need to be plugged back into the hoses on the manifolds, or plugged at the manifold. Big vacuum leak if left open.
