Bobalos
- 5,299
I see you solve problems similarly. Lol
Want to borrow my 4’ brake to make a blister?
i think one or more of the vacuum pods are going out now... doors are not opening like they should....I see you solve problems similarly. Lol
I have a 28” brake that should be big enough. I keep waffling back and forth on just buying a fiberglass one, and making one.Want to borrow my 4’ brake to make a blister?
Put a Mityvac on the main hose to test it?i think one or more of the vacuum pods are going out now... doors are not opening like they should....
That's a good look right there.View attachment 110519this would be a look .... or really screw people up and mount it backwards..
Or the home depot solution...
Thanks for rocking the shirt ... and not inviting me :-(On 7/15/2024 at 6:33 PM, Rockwood said:
You have a 4WD?Thanks for rocking the shirt ... and not inviting me :-(
Amusingly, we swapped out his entire cooling system (pump, temp sender, fan clutch, radiator, thermostat and housing) up there to fix it. Not sure what the problem was, but since we had it all apart, might as well. Ran cool all weekend after that.You should convince your LJ buddy to run this.
https://www.rockauto.com/en/parts/gm+genuine,1581927,radiator+fan+assembly,2181
