Ganzo
- Jan 1, 2023
- 103
- 10
The wiring is on there. I spoke to harvey to ask about o2 sensor if it was needed and he said no.
Start with fuel filters. Make sure you have fresh fuel. Put a gauge on your regulator and make sure it’s set right. Also if this is a recent junkyard motor make sure injectors are squirting.Maybe my fuel regulator took a dump?
I used the below.Does anyone have a parts list for a built turbo J35 setup? My dad has a J35A4 now. I am considering building a turbo setup but want something reliable. Not a ticking time bomb
Did you use the cylinder supports? And what heads did you run?I used the below.
https://www.wiseco.com/product/auto/pistons/professional-honda-j35-piston-set-89-25-mm-bore/
https://powerrevracing.com/products/acl-race-series-main-bearings-for-j32-j35
https://powerrevracing.com/products/acl-race-series-rod-bearings-for-j32-j35
https://powerrevracing.com/products/arp-head-studs-for-honda-v6-j-series-engines
https://powerrevracing.com/products/j35-h-beam-connecting-rods-with-superfinishing
Two season in and its super solid. Made 500WHP at 10 lbs and is a ripper.
I did not and I used stock J35A4 heads.Did you use the cylinder supports? And what heads did you run?
You sure it’s 4500? I could never get my tac to work properly.Guys i just got my j35 on my baja running and when i hit 4500rpm it hits rev limiter. Any advice?
Did you check the wiring on the tach to make sure it was wired for 6 cylinders and not 4 or 8You sure it’s 4500? I could never get my tac to work properly.
I have forgot to plug in the wires for the vtec thingy in on the filter housing and it acted like it was hitting the rev limiter, but I think it was earlier than 4500, may be worth a try though.So i am hitting 4500 rpm and it hits rev limiter. I checked for codes and the one that stood out was P0335 which is crank position sensor which i replaced but it still does the same thing. I have not checked for codes again but am thinking that it may be the wiring harness for the crank sensor?
Have you replaced the sensor?Ok so I connected the OBD and tach was reading wrong. Turns out the engine starts cutting off at 3k rpm. It keeps throwing the crank position sensor code and when you hit erase code the car turns off. Any ideas?
Yes sir. Replaced and still same faultHave you replaced the sensor?
