- Thread starter
- #621
onanysunday
- May 7, 2021
- 3,741
- 3,442
How much weight was on it and also how many isolators did you use? I'm guessing that intercooler and framework is 10 to 15 lb and I'm spreading the load over eight isolators. Hopefully enough. It will be easy to change to a different style if I need to down the road.We used to use those at work, but stopped because the bolt does not go all the way through.
After a bit of time and a good bump and they rip. Mind you our application is way different. We changed over to through bolt types.
