The GM52 Hustler clone conversion
Yes sir.
New rear shocks came in.  John's balancing the engines rotating assembly now. Heads and ported and polished and going out for the valve job. I believe they are getting inconell valves.
Timing cover, valve cover and accessories have been powder coated.
Moving along.
Yes sir.
Moving along.
Good to hear things are moving along.
Summer goes by real fast.
Boy I missed some stuff.............I thought you already did all this stuff!
Little tech talk.
The old 3.0 platform used a crankshaft driven oil pump.
The new 3.6 platform uses a cam driven oil pump.
Due to the cam speed difference, Subaru went way up in pump size.
Check out the difference.
Wow...a lot bigger but looks way better!
Little tech talk.
What's the reason for and benefit of the change?  (crank driven vs cam driven)
