### **2024 SNORE Speed UTV Rage at the River Race Recap**
Last weekend, the 2024 SNORE Speed UTV Rage at the River brought the racing season to an exciting close with its iconic 3-day showdown in Laughlin, Nevada. With nearly 90 UTV entries, this event was one of the most competitive and largest races of the year. Drivers Robby Gordon, Max Gordon, Todd Romano, and Bronsen Chiaramonte represented Speed UTV in the highly competitive SXS Pro Turbo Class, using the race as a proving ground for cutting-edge product developments and design updates.
### **Race Overview**
The Rage at the River is a short-course sprint race like no other. Cars start four-wide, demanding top-notch performance from both drivers and vehicles. The course features sustained wide-open throttle sections with speeds exceeding 100 MPH, massive whoops ("Moon Bumps"), technical infield sections, and high-flying jumps. This challenging combination tested every aspect of vehicle performance, including suspension, cooling, clutching, and powertrain durability.
### **Testing Objectives**
Speed UTV leveraged this race to test several key developments:
- **E85 Tune**: Robby, Max, and Bronsen ran E85 to evaluate its performance and the durability of the clutching and belts.
- **Pump Gas Tune**: Todd ran the stock tune for the same comparative data.
- **Suspension Setup**: The course’s had a mix of whoops, jumps, high-speed chatter, and tight corners.
- **Cooling Systems**: Sustained wide-open throttle and muddy conditions tested the limits of engine cooling, including water, oil, and intake charge temperatures.
### **Qualifying Recap**
Day 1 qualifying showcased the potential of Speed UTV’s efforts:
- **Bronsen Chiaramonte and Max Gordon**: Dominated qualifying, taking 1st and 2nd with a 4-second margin over the nearest competitor.
- **Robby Gordon and Todd Romano**: Encountered setbacks when both entered limp mode: A disconnected ECUs or Battery requires time to relearn max boost settings. Any form of wheel spin can during the relearn process can cause over boost and will put the car in limp mode. This happened during qualifying and put both cars in limp mode midway through the qualifying lap. Despite this, valuable lessons were learned and will be shared through service centers and the owner’s manual. Going forward any vehicle that has an ECU re-flash or battery disconnect will require a specific relearn process, that will teach the ECU its boost thresholds and targets. If over boost is ever experienced during the re learn process, you can shut the car off entirely and on restart it will clear limp mode and continue to relearn.
### **Race Day 1**
The first race day proved to be as demanding as expected:
- **Max Gordon**: Suffered an oil line failure on lap one, sidelining him early.
- **Robby Gordon**: Retired after sustaining damage to the oil pan, ending his weekend prematurely.
- **Bronsen Chiaramonte**: Finished 6th, hindered by a blown CVT belt due to high of an RPM with the E85 clutch setup. Adjustments were made overnight to add clutch weight for Day 2.
- **Todd Romano**: Encountered a broken rim and axle after avoiding a rolled competitor, costing 20 minutes and relegating him to 23rd place. Despite the setback, the production *El Diablo* was making its way through the pack.
### **Race Day 2**
Day 2 was cut short by a red flag after a major crash on lap 3, but the team continued to gather critical data:
- **Bronsen Chiaramonte**: Finished 4th, just a minute behind the winner. Adjusted clutch weights improved RPM control but revealed belt slip at 75 MPH. This valuable insight has us looking into future secondary spring development to better handle the increased torque of the E85 tune while lowering the overall max RPM.
- **Max Gordon**: Suffered a shock failure due to the course’s punishing demands, ending his day early.
- **Todd Romano**: Battled through the field from the back but lost time due to a right rear axle failure caused by wheel-to-wheel contact while passing a competitor. Despite this, Todd’s production *El Diablo* continued to demonstrate reliability and competitiveness.
- **Robby Gordon**: Did not race Day 2, as he departed for Vietnam to oversee 2025 vehicle builds.
### **Key Takeaways**
The 2024 SNORE Speed UTV Rage at the River provided valuable insights:
- **Cooling Systems**: No vehicles experienced overheating, even under the harshest conditions.
- **Suspension Performance**: The Speed cars, handled the mixed terrain and challenging conditions as expected, allowing the Speed team to racer the front all day.
- **Clutching and Belts**: Significant progress was made and additional testing and tuning will be done to allow both the E85 and pump gas tunes to get the most from the motor and top speed.
- **Production Car Development**: Todd’s production car proved to be reliable and is closing the gap to podium pace. Todd raced in a production *El Diablo* running our pump gas tune. One of the key limitations we identified was in top speed. While the E85 tune allowed cars to achieve speeds over 100 MPH uphill and 105–110 MPH downhill, the pump gas tune maxed out at 75 MPH in the uphill sand washes and 100 MPH downhill. This difference significantly impacted lap times, especially on the high-speed sections. Moving forward, we plan to conduct additional testing to find ways to recover some of that lost speed.
### **Final Thoughts**
Speed UTV thanks the racers, fans, customers, and SNORE for an incredible season finale. Despite the challenges, the team’s efforts paid off, with a 1-2 finish in qualifying and Bronsen Chiaramonte securing 6th and 4th place finishes on days 1 and 2. The production *El Diablo* continues to evolve, showcasing its potential as a competitive and dependable platform. We look forward to building on these successes in 2025!
