- Thread starter
- #3,341
Sand Shark
- 5,387
The Pro R is a 4 cylinder motor. Not sure how much it weighs. The cars will shed a little weight with a paddle tire set up as those 32" dirt tires/wheel combo are in the 65lb+ range. All the little stuff they put on the UTV just add up.Well lets see, i have a full aluminum body, the roof is .125" thick., my floor is steel expanded metal, my tranny has to weigh more than a 300hp mini tranny and a front diff (and my trannys can support 6-800 hp.) rear trailing arms with 12" brakes, 4 934 cvs and my axles weigh more than any mini driveshafts. I might be missing two rear seats but my car is still a four seater. the rear doors are not there but i have steel tubing there in its place. in the place (of the back two seats) i have a radiator full of water that is 31" wide by 19" tall and (hardly the size of the sxs radiator). with all that water weight and two large 16 paddle blades, my intercooler is twice the size and weight with two large 12" paddle blades. lastly my 6 cylinder engine clearly is easily twice the weight of a two cylinder engine. Its still baffling the weight but i get it....................
I thought you did a lot of stuff to shave some weight off you car.
I will be curious to see how much my friend's Funco will weigh when he is done with his remodel. He has a Gen 4 that he is removing the back seats and making a 2 seater. Adding a big fuel cell, converting the suspension to the bigger stuff, and he will be running a turbo Honda motor.
