onanysunday
- May 7, 2021
- 3,350
- 3,115
Figured the sandrail world could apply here. Some here have been following my Dodge A100 hot rod build. Been dreaming about my next car and want to build a 52-62 Metropolitan Nash for my wife. Autoweld Chassis in Pennsylvania built this chassis for a company that builds Metropolitans. Super cool and they only built one. Tons of design and I like everything they did. He said they spent a lot of time designing everything. He could not remember the engine but I think it could be the GM 3.6 V6. He remembered it was from a Cadillac and 305 HP. Maybe someone here can tell what that engine is by the pics? I like everything about that chassis and setup. He still has all the drawings and a Complete roller from them is $16k. My thought was to put a small turbo on it with mild boost and bump it from 300 to 400 HP. These cars stock are 1800-1900 lbs. I would think a light v6 or 4 cylinder and that chassis you would end up around 2600-2700 lbs. (I heard a V8 car was 2800 lbs) Might be cool to mount the turbo and intercooler in the back of the car and run piping. Although the fuel tank would have to go back there and not sure about a turbo close to the fuel tank. What about an Ecotec with some boost? Other engine options? I don't think a Subie would fit? These cars are very narrow. The setup they did looks to have a 6l80e trans which is crazy. He said there was going to be room for a foot box. I would think with something like that you could put 411 gears in it for the 9". Maybe run a 4l60 instead? Not sure what adapters are out there for different engines. I am thinking 400 hp on Pump premium gas. I did mention an LS to him but he thought that engine was to big. Although I have seen these cars with V8s.
Dimensions
Wheelbase
85 in (2,159 mm)
Length
149.5 in (3,797 mm)[1]
Width
61.5 in (1,562 mm)
Height
54.5 in (1,384 mm)[2]
Curb weight
1,785–1,890 lb (810–857 kg) (base)
