- Thread starter
- #741
ChEFF
Forum Moderator
- 10,671
My question is what did your Civil grading and drainage plans say?There used to be a ditch before development of the property. The ditch had to go away for me to connect to the street. If I kept the ditch in place, have you ever driven a motorhome across a ditch? Talk about Rockin and Rollin. Peace
Does the water flow from his house to yours ? or the other way ? I would start off by telling him to locate that pipe on the other end. At that point you can have a discussion. Even if that pipe didn't come out on your side of things and there was a ditch where it should of come out, that you filled in. Your the unlucky bastard I am afraid. What I didn't see though was where the ditch you had across your property flowed into. Who know's it might go for 2 or 3 houses before coming back up.Here's the neighbors ditch. Remember, this culvert NEVER flowed out to my property. Peace
Kind of looks to me as he created a rock bed lake in his front yard. Surrounding areas like your drive drain as they did prior to slab, and they still do. What changed?Yes. He's at the TOP of the street. BUT........................The water never flowed down his pipe thru my property. It always went above the ground. Our street is a steep grade downward to the lake. When they moved in he did that rock work. So, maybe I could offer to buy his rock, provide the dirt to fill his swell, and the water flows over our driveways down to the lake. It would be so much cheaper and easier to fill in his void than to cut my place up. Just a thought. Peace
BTW do you explain to this peasant exactly who you are??
Lacking for sure RobertL. ! PeaceYet there isn’t any updated pictures. You know the drill ChEFF
