LtPyro
- May 6, 2021
- 182
- 71
Nice findSome other J series goodies to go along with the above post.
https://www.swervedrivespecialties.com/collections/j-series-miata/products/power-steering-pump-mounting-kit-j-series-miata
i run a mishimoto 154* thermostatSpeaking of plumbing, are most of you guys running thermostats on your Hondas?
Noticed the PO cut off the thermostat housing and welded in a hose fitting. Its takes a while to warm ups, but other than that, not sure if there would be any issues with no T-stat?
Your stereo won't draw 100 amps 100% of the time.I have a Honda j30a1 and planning on putting in a stereo system with a max wattage of 1320 and amp in the 100 range.
Quick search states that OEM alternator outputs like 80 amps. My stereo would draw approx 100 amps plus my LED bar, LED chase light and 4 cube LED lights.
What alternator can I buy as a replacement and do I need a different size of belt?
Thanks!
Thanks!Your stereo won't draw 100 amps 100% of the time.
However, the Odyssey one is rated higher. 130a. https://www.autozone.com/batteries-starting-and-charging/alternator/p/duralast-alternator-12307/784181_0_0
That probably has more to do with the interference the radio is causing than volt drop. There was a LONG thread about that on the old board about engines dying when the mic was keyed.I have the Odyssey alternator in my car. With my car idling, Fans/whips/Lights/dash lights/iPad/Intercom and Radio on, if I key up the radio to talk car to car, the engine stumbles and almost dies.
I have a 250amp high output alternator on order. I plan to put a stereo in the car and if I already have electrical shortages, I dont want to play around.
YesThanks!
I should be able to run the same belt that’s on it now, correct?
The radio can interfere with the computer? Never even thought that was possible. I ran separate power and ground lines for the intercom/radio. Plus the radio is in the dash and the ECU is in the back of the car.That probably has more to do with the interference the radio is causing than volt drop. There was a LONG thread about that on the old board about engines dying when the mic was keyed.
Ohh... My antenna is literally 12" above my Motec ECU. You think that could be the issue?The radio can interfere with the computer? Never even thought that was possible. I ran separate power and ground lines for the intercom/radio. Plus the radio is in the dash and the ECU is in the back of the car.
The bottom end may not really tell you anything. The ASSuming the intake is the one that came with the engine, that's the easiest way to tell. Looking at the rocker/VTEC assembly can tell you if it has A1 or A3/4 heads...also assuming someone didn't start swapping parts around..Went to G last week for a few days to do a shake down run with the car. Made a bunch of changes (added radios and misc stuff like that) and had a rough go.
The car overheated bad, gauge was pegged at 250+. Which I attributed to running hard in 2nd and not shifting to 3rd sooner. Last night I had a some time to pressure test the radiator (leak down test will be done tomorrow), found 2 leaks, one in the rubber hose connecting the water manifold to the radiator piping and the other... appears to be a small crack in the radiator. Im hoping this is it, but I may need to pull the heads if the leak down doesnt go well.
My question is... I have a stamped J35A, but I dont know what version. Is there a way to tell without tearing into the bottom end?
Could be. @CHIZZLE was the one who was battling the issue, and had the thread. Maybe he can chime in about it. IIRC, others stated they had similar problems.Ohh... My antenna is literally 12" above my Motec ECU. You think that could be the issue?
I'm not positive but I was told these are how JDM motors are stamped.Went to G last week for a few days to do a shake down run with the car. Made a bunch of changes (added radios and misc stuff like that) and had a rough go.
I battled over heating issues with mine a few years ago. Changing out the water sensor to the 175 degree one that was posted in this thread really helped. Beforehand my fans weren't coming on until 205, but by the time they could start cooling the car down, the temp was at 220, then it would only cool to 205, and this cycle would continue and never cool the car down. What I did to test it was add the fans to a switch and I would turn them on at 175, car never got over 200 again. I also replace my fans because the blades were worn down from sand.Went to G last week for a few days to do a shake down run with the car. Made a bunch of changes (added radios and misc stuff like that) and had a rough go.
Has to be a stand alone ECU. Some are capable of running a drive by wire t-body, some not. There is an adapter for the later engines to use the early t-body, but still must run a stand alone ECU.I'm looking into using a j35 for my baja bug build so I have lots of questions. From the quick research I've done so far it looks like most people are using j35a4's. I'm assuming that's because it is still cable throttle. They still seem fairly plentiful. Are newer j35's with flyby wire throttles too hard to deal with? Are good wiring diagrams easy to come by?
I've done a few engine swaps. My LS based swap was fairly easy with the amount of info out there on the net. It was the most extensive I've done with stripping down a wiring harness. My buddy did a quick ecm tune and it was good to go.
Also what's the best way to source an engine, pick and pull yards? For my Ls I called around and was able to get a package deal with everything from a junkyard.
