Big_Daddy_Jp
- 1,260
I thought the current law was 1000cc and below. Not that I wouldn’t wear one anyways, just figured they would have to change it.I would think so. The will likely just adapt the helmet law.
Polaris will likely go back to the same people they went to the first time and try to get them to back expanding the 1000 CC cut off point to now include this and anything else they might have in the works. Either way it might be the opportunity for the jackwads in Sacramento to save the world from themselves and will just amend the legislation that everybody gets to wear a helmet. So now the Rail guy's who had the option will no longer have the option.I thought the current law was 1000cc and below. Not that I wouldn’t wear one anyways, just figured they would have to change it.
Well I guess you would say 'tuned'. I know everything in CA is lean to pass CARB (and they tend to run hot - another indicator of 'lean'). Adding a slip on/air filter/charge tube only exacerbates the lean condition. I run AA tune (level 2) in the turbo S (which is essentially limiters removed and extra fuel). IIRC the tuner can monitor AFR in the CA version (blue O2 sensor) but level 2 is fine for for me. I have level 3 on there, but maybe iffy on CA 91 pump on a hot day?Chipped, or tuned? How are you reading AFR to say it's too lean stock?
-TJ
I don't think I could go back to a non-turbo SXS. A little octane booster and 91 on those hot days works. I ran octane booster on my tuned X3 when in the dunes.Well I guess you would say 'tuned'. I know everything in CA is lean to pass CARB (and they tend to run hot - another indicator of 'lean'). Adding a slip on/air filter/charge tube only exacerbates the lean condition. I run AA tune (level 2) in the turbo S (which is essentially limiters removed and extra fuel). IIRC the tuner can monitor AFR in the CA version (blue O2 sensor) but level 2 is fine for for me. I have level 3 on there, but maybe iffy on CA 91 pump on a hot day?
You mean like the Wildcat had 9 years ago? LOL.Looks like a track bar to help control the track of the suspension as it cycles. The front shocks mounting to the lower a-arm is a nice touch too.
crazy to think Polaris had this concept more than 2 speed years ago.
You'll get pulled over anyway. Rangers won't know the difference.Not sure if anyone has asked the question but will helmets be mandatory now that they are going over 1000cc’s?
i think they are going to be considered something other than a UTV. speed has gotten patens and im sure all the other manufactures have patens on their stuff as well for a utv class. so my thinking if you come out with another class of vehicle you possibly can get around the paten infringements. so going to a 4 cylinder well over 1000 cc makes it no longer a UTV just saying200hp n/a UTV is impressive. Their current n/a car is 110hp. The fact Polaris said f’ it and when to a 4 banger engine is pretty cool.
If will likely be a heavy SXS.
Who knows if they did anything to the engine. That fuel is a UTV fuel and not 110octane. No clue if those are aftermarket trailing arms or a-arms. We have not see the production car to compare.
I can appreciate what Polaris is doing just like what RG is trying to do with the Speed UTV.
I want to see the full specs.
Those prices would seem about right.Since we don’t know the different trims and possible engine displacements in the new Pro R. What’s everyone’s guess as to the base 2 seat & base 4 seat Pro R pricing?
Im thinking if there is going to be different engine displacement options, I’m going to say the 2 seat is $28.999 & the 4 seat will start at 31,999.
Rumor is Polaris is calling it a buggy. We shall see on 11/9i think they are going to be considered something other than a UTV. speed has gotten patens and im sure all the other manufactures have patens on their stuff as well for a utv class. so my thinking if you come out with another class of vehicle you possibly can get around the paten infringements. so going to a 4 cylinder well over 1000 cc makes it no longer a UTV just saying
Nick from Chupacabra guessed $37k and $40k.Since we don’t know the different trims and possible engine displacements in the new Pro R. What’s everyone’s guess as to the base 2 seat & base 4 seat Pro R pricing?
Yep I hated my 09 built Teryx for this very reason, PITA multi hour job to change the belt, partially why I ended up in a yxz.Yup.. I think it's a bad move to change so much stuff... if the belt is only change-able under the seat.. it's garbage..
To make a Turbo S.. a decent ride.. you're $40k+.. .believe me.. I know.
abc
HUH????In Polaris defense, CVT’s have got way better since the RZR 800 days. You don’t see or hear about blowing belts like we used too.
Next issue is packaging for the new Pro R. I don’t see how they could mount the CVT any other way with the size of the engine & crankshaft direction on the engine. As it is the rear is using a separate rear independent differential vs a transaxle configuration.
Id be more concerned about the 6-7 u-joints & 2-3 carrier bearings they looked to be using. Polaris has had many issues with u-joints & carrier bearings over the years with several models.
There is something wrong with either the clutch/clutch setup, or the nut behind the wheel. I run our '18 XPT from time to time, when the rail is down or just for shits 'n giggles. I know I've posted these pics on this forum multiple times, but this wa a hot day (90+) late in the season when the dunes were empty and we were jamming. I did have to slow-up for ECTs (not dangerous, but when I get to 217-219 I check up) after a looooong session following these guys (well, following 2, I passed the Tatum) but I had NO belt issues on this run:HUH????
My buddies son blows at least 1 belt a trip.
He spent a chunk of change on 3 belts from the mullet. LOL
He does do well keeping up with all of us in buggies. And we ain't slow. LOLDon’t know your friends son, but I’m guessing he’s just a mash & go type of driver. Maybe he’s a candidate for a belt temp sensor? Maybe he does not know how to drive with a CVT. Just like some can’t drive with a clutch or sequential. I myself have learned how to drive with a CVT and do not have belt issues. I personally don’t know anyone who has regular belt failures.
I did help a guy on a trail once who had a flat and broken belt. We gave him my spare tire to get back to camp on, and another guy in our group gave him a used belt to get back on. When we got him back to his camp and to get our tire & belt back, all he complained about is what a pile of junk his RZR was. He talked about blowing belts, breaking axles etc.. He’s a guy who could break an Albins with a VW engine.
