- Apr 29, 2021
- 2,731
- 4,217
Welcome back @Punisheri remember a non funco 3000lb blown ls3 coming is 2nd place a couple years ago....
so far on pump gas 975 hp and 880 tq. Torque is at 3200 rpm and carries all the way to 6500. even at 6500 TQ is 830. should be good. going a little race mix once the car is ready.please do post numbers. im not a V8 guy but if i had one it would look like yours!
Watching the vid above, you already have way more than you'd be able to use in a course of that configuration effectively. The low end torque will be a huge boon if you can keep the front down and get it moving you forward, not up... which the Funcos do amazingly well. I'm impressed with mine that's said to be something like 700 RWHP (though I'd guess a bit lower) as far as putting power down and getting off the corner. But, anyway, I wouldn't focus too much more on top-end HP and "numbers." 975 HP is already a fug-ton for 91 octane at 440cui...so far on pump gas 975 hp and 880 tq. Torque is at 3200 rpm and carries all the way to 6500. even at 6500 TQ is 830. should be good. going a little race mix once the car is ready.
Yep - i figured you'd have some carnage from running that hard - but it's the ability to focus and adjust after you've broken something while racing that separates the participants - what/how you do under pressure/when something goes wrongRe: the video......i cant see it either at the shop but can on my phone
broken parts: One year i blew 2nd gear on my sequential during the race. any of you who have had a blown gear know you can double shift and pass right through the gear so from 1st gear i can shift twice into third or down shift twice to get back to first. the problem was i was not expecting it and it took a few seconds to realize what had happened and which gear to avoid (shift pass)
another time i showed up and my right rear lower air bag perch bolt was broken very badly. the bag and perch was basically just sitting in the arm. that was found after the parade lap. I had some old bolts back at camp. we went back and with help of everyone was able to pound out the old bolt and inserter a new one with just the help out there. yes, that required like 10 guys to lift the car up so arm would hang down while i lined up the holes and pounded in a longer than normal 1/2 bolt, aired it up and then raced
another year: the next morning after the race was the Funco regatta. I have a unique shifter cable set up that i will show pics of later, any ways there was a single 1/4-20 bolt single shear bolt for a "shifter cable reverser" that broke right when i parked my car for the picture. realizing after the group foto i would be stranded down there and not be "cool" and drive away like the rest of the cars to take a jump--i asked a stranger to take me back to my camp in his razor, in road runner and got a spare bolt, came back and changed it out while no body knew. if that had happened in the race 20 hours earlier i dont think i could have won.
there have been some close ones.......................... but luckily never have had a motor issue so i like my motor builder a lot!![]()
I've used the general mantra of he posted in his old Gen 5 thread (move weight forward, but somewhere in the middle of the wheelbase) as much as possible on my last build, as well as other tips I've learned from this board (rear-biased tire inflation being huge). Most of the guys in camp are pretty much set up fast. Whenever a new guy joins us, we put him 3rd behind me (I run "cleanup" to keep everything smooth and fun) and every single time that newbie comes over to check out why the F he wasn't able to hang with the 4-banger beam car. Most don't want to try The Setup because they "just want to wheelie" or don't like how unstable it is.John moves up more than he moves down on the list, That is what makes him so hard to beat. What is really funny is that for the set up he detailed his set up and the people he beat told him either he was going about it wrong or it didn't matter that much.
30102082. 1876 CFM. They require a 40 amp circuit so I used to use an inline maxi fuse. No ATCb fuse holder can support this fan with any long term use and high duty cyclesWhat 16” fans are you running?
Agree. I’ve melted my fair share of those holders with 30a fuses in them running fans. Fuse was fine, but the whole holder was a melted disaster. Never again for anything larger than a 20a.30102082. 1876 CFM. They require a 40 amp circuit so I used to use an inline maxi fuse. No ATCb fuse holder can support this fan with any long term use and high duty cycles
