Kraut_n_Rice
Site Sponsor
- May 9, 2021
- 3,177
- 2,480
Don't forget that V-tec hit yo.... :dunerdude:Even without boost, still 50-70hp (in swap trim) and 20lb-ft with a much wider powerband over a new 4L.
Oh, and probably 150lbs lighter. Lol.
Don't get me wrong, I totally agree (remember, I did have a J35 A4 4 seat buggy as my first rail...) but just figured it'd be one of those "well if I'm going to swap the damn thing... have to at least make 300HP..." deals.Even without boost, still 50-70hp (in swap trim) and 20lb-ft with a much wider powerband over a new 4L.
To further derail this....Don't get me wrong, I totally agree (remember, I did have a J35 A4 4 seat buggy as my first rail...) but just figured it'd be one of those "well if I'm going to swap the damn thing... have to at least make 300HP..." deals.
-TJ
It’s worthy discussion, F it.To further derail this....
I did a swap on a Funco from a turbo subi (2.0 it think) to a NA 3.5J. The owner did hub dynos before and after at the same place. The subi did like 219. The Honda did 265, through a 091. The 245 Honda tags it with is terribly under rated.
Maaaaybe? It’s a 4-door XJ, so 37s are the max before stupid shet needs to happen to the body and the gas tank ends up in the trunk.Atlas and super duty axles next?
Would’ve had to buy chit, mainly. LolSo, why not go LS1/6 intake and accessory drive so you don't have to cut the hood?
A well setup XJ on 37s will mob nearly everything you would want to reasonably do. And, chit you might not..Maaaaybe? It’s a 4-door XJ, so 37s are the max before stupid shet needs to happen to the body and the gas tank ends up in the trunk.
We shall see. If anything, I might do a 1G Super Duty Dana 50/Sterling swap because you can shave the 50’s housing down to near D30 clearance.
Bought all the tools to DIY regears, so at least failure repairs won’t be terrible cost wise.
My J35 A4 that was well worn (later investigation showed it had been turbo at some point... things like a plugged oil return welded into the pan etc.) did 236 RWHP (and I think the same RWTQ) or something like that through the 091 with an AEM on it.To further derail this....
So fukin rowdy.2 hours ago, tjZ06 said:
Total thread hijack, since I guess I don't have a thread on my WJ. More unibody Heep motor-swap content:
Wiring tucked away. LS fuse block is behind the kick panel, OBDII port in the stock Jeep spot, LS MIL in the stock Jeep cluster. Need to get the LS ECM’s fan turn on temp for the AUX fan raised. Turns on when the thermostat opens currently. Also need to reprogram the tach output mode so it will interface as a “crank position sensor” for the Jeep’s ECU and make the tach and AC work like factory. Is that the same 2 door you had for sale forever? If so, can't believe you still have it, it's a nice rig.A well setup XJ on 37s will mob nearly everything you would want to reasonably do. And, chit you might not..
MY XJ is already on long arms. It will be a touch more aggressive then my LJ when I get around to doing it. 37/38s, 60s/50/Sterlings.. Fenders are already trimmed way back, but I won't cut into the body. I'm not interested in doing a full coil over conversion on it. My wife want's to make a halfazzed overlander out of it....sleep in the back...mine's 2dr...6'+ hatch to front seats. Slide out kitchen stuff.
Anyway...burnout vids next?
Haha, same. Though with the WJ finally coming together I'm selling my XJ. The 4.0 has the usual 4.0 tick (despite a new-ish head etc.). So of course I've been looking at that nice Edelbrock head... and nice cam/lifter/rockers... and 4.6 strokers... and...Reading the motor swap info gives me a headache. I'm happy with my little 400k mile 4.slow.
Don't do it TJ .... lolHaha, same. Though with the WJ finally coming together I'm selling my XJ. The 4.0 has the usual 4.0 tick (despite a new-ish head etc.). So of course I've been looking at that nice Edelbrock head... and nice cam/lifter/rockers... and 4.6 strokers... and...
-TJ
I'm not going to. The XJ will be gone as soon as the WJ is drivable, or sooner.Don't do it TJ .... lol
