- Thread starter
- #201
SeanRitchie
- May 6, 2021
- 472
- 1,087
I would say the S4D would be a great option for this. Yes, the Albins does have some overall better components, but the S4D has proven itself to hold up exceptional well since we got everything working properly over the past 10 years.@Sean@Weddle I'm waiting patiently in line for my new car and will need to select the gear box relatively soon. My decision will be between an S5D or pony up more for the Albins. Engine selection is made, going with the RHS 427 and Whipple 4.5 on pump gas. I'm told it should make just over 1k at crank and high 700's, maybe right at 800 at rear wheels. I would rather spend money elsewhere than going with Albins. I'm told the S5D are same gears and R&P but the Albins has stronger main shaft bearing. Is this correct? Any reason the S5D would be a concern with my engine selection? Car is a Funco so won't have tall tires. And car will not get a lot of miles in a season. Input greatly appreciated.
I would not recommend the 5-speed for anything over 800 ft/lbs at the crank, 2nd gear gets a bit weak with that kind of power. The 4-speed would be perfectly fine for any high powered sand car and will have much stronger gears. Most people only use 2-3 gears anyways.
