Ganzo
- Jan 1, 2023
- 115
- 14
hey guys im looking at installing the air filter and was looking at options. anyone know where to buy a standoff or something to hold an airfilter to the roll cage?
https://www.arizonaperformanceimports.com/parts.htmlwhere are these available at?
You can not tune a stock ECU.Question, those of you that have a stock ecu, is it worth it to tune it for a stock j35?
If they are A2 heads it would be a good swap. Bigger cam and valves. A1 heads, don't bother.ok yea i have a j35a4 in my baja so its pointless to swap heads i guess huh
Will lowering the crossover help other than make it noisier?There are vtec controllers available in the aftermarket where you can set it to engage at whatever RPM you'd like.
https://www.swapshopracing.com/contents/en-us/p7666_Buddy_Club_V-CON_VTEC_Controller.html
Dunno. Someone with dyno time coming up could verify.Will lowering the crossover help other than make it noisier?
I would highly advise you to always run the covers. You dont want sand in there. Especially with the camp positioning sensor at the top and the crank positioning sensor at the bottom.does anyone run their j series without the timing belt covers? if so, it doesnt mess it up the sand and dirt?
It will also chew up the seal up front.does anyone run their j series without the timing belt covers? if so, it doesnt mess it up the sand and dirt?
Would never consider it.does anyone run their j series without the timing belt covers? if so, it doesnt mess it up the sand and dirt?
