- Thread starter
- #221
onanysunday
- May 7, 2021
- 3,502
- 3,326
I'm having a hard timing figuring this out. Is this an LS with a carb intke or a gen1 with some kind of CNP ignition?
It is a late model hemi with coils but then has a carb. Very unique setup.I'm having a hard timing figuring this out. Is this an LS with a carb intke or a gen1 with some kind of CNP ignition?
In any case SUPER cool truck. I don't think though that the later model seats look natural in these early trucks. Something about it don't look right....
Possible solution. Although I really want to try hide as much stuff as possible and have bed around the engine in the back. Cut some more out of there and now I have enough air flow that I am happy the radiator will work correctly. Very likely that intercooler is not going to work. Once the frame is completely built and after breaks and steering then I can look at it.Air to water would probably be easier to package.
Then they also have idler gears with sealed bearings HERE. So the 17 tooth with 5/8 shaft might be the right size. Maybe just buy 6 of these sprockets and build it. Make the tensioner adjustable with a slider if the chain stretches. This number 50 chain is probably overkill but it shows what is available. So 3 gears would be $543.00. Chain, links, and tooling another maybe $200.00. Shoot the flaming river 90 degree box is $800 by itself. The rest would be all fabrication. Working load on that number 50-2 wide chain is 2350 lbs whatever that means. Probably overkill for steering. The hot setup would be design it to hold some oil to keep the chain lubed. Much harder to design and build. Not sure if just grease in an enclosed box would be enough.Number
of Teeth
For Shaft
Dia.
For Max.
Shaft Dia.
OD
Overall
Wd.
Hub Dia.
Material
Each
For ANSI 50-2 Roller Chain (5/8" Pitch)
11
5/8"
15/16"
2.5"
1 3/4"
1 15/32"
Steel
2784K33
$95.78
12
5/8"
1 1/8"
2.71"
1 3/4"
1 11/16"
Steel
2784K34
96.16
13
5/8"
1 5/16"
2.91"
1 3/4"
1 7/8"
Steel
2784K35
98.67
14
5/8"
1 3/8"
3.11"
1 3/4"
2 1/16"
Steel
2784K36
100.76
15
3/4"
1 1/2"
3.32"
1 3/4"
2 5/16"
Steel
2784K37
100.76
16
3/4"
1 3/4"
3.52"
1 3/4"
2 1/2"
Steel
2784K38
103.36
17
3/4"
1 7/8"
3.72"
1 3/4"
2 11/16"
Steel
2784K39
106.07
18
3/4"
1 15/16"
3.92"
1 3/4"
2 7/8"
Steel
2784K41
108.67
19
1"
2 1/8"
4.12"
1 3/4"
3 1/8"
Steel
2784K42
110.44
20
1"
2 1/4"
4.32"
1 3/4"
3 1/4"
Steel
2784K43
114.69
In Arizona I think they drew the line at rope.He said chain drive steering is not legal in some states.
