- Thread starter
- #181
onanysunday
- May 7, 2021
- 3,504
- 3,326
Yeah that would be pretty cool. mount a propane tank up under it somewhere.I guess you know the old wheel standers use to inject propane in the exhaust for the fire. DON~~~
Just be careful raping the motor while injecting the propane. Don~~~Yeah that would be pretty cool. mount a propane tank up under it somewhere.
Leave it in its original location and clearance the upper arms. Can't see that small amount of materials going to weaken it in that location.53 minutes ago, onanysunday said:
I thought of that but really did not want to cut into the arm. There is not much there and I think it would certainly weaken it. Especially on this truck with the weight bias possibly being more weight on the rear than on the front of the truck. I went just a little bit further and it is centered pretty close. It really only moves that upper mount in and forward slightly. I can't imagine that changing the geometry very much. It's easy to rotate back and forth and drill additional holes if necessary later on. It will not weaken that casting. It is plenty beefy in there. I almost think I'm going to have to get this thing all built and sitting at ride height and then play with spacing and shimming on the shocks. But at least now I can go up or down. One thing is for sure I want the truck sitting at ride height to be the same as a regular Corvette. Meaning the relationship of the a arms in relationship to the cradle. Those GM engineers are some smart fellas.Leave it in its original location and clearance the upper arms. Can't see that small amount of materials going to weaken it in that location.
I wouldn't think that would change geometry at all. Only change amount of load support as angle changes imo. Which is a non issue as air pressure can be increased or decreased for desired ride height.I can't imagine that changing the geometry very much
