danwalker
- May 6, 2021
- 244
- 244
Getting somewhere now...
opcorn:
Yep kind of fun seeing it look like something. Started tearing the front apart today. What's funny is earlier I went to actually bolt the sway bar on the rear. LOL oops that won't fit. Talking to one of our customers he said the steel that those sway bars are made out of are not good to cut out a section and weld back together. He suggested possibly torsion bars which sounds interesting.Getting somewhere now...opcorn:
So imo the rectangle tube will only deflect energy in two directions. Given the hp you wish to run my concern would be limiting the twist to the frame. With our sand cars and round tube, energy is deflected in all directions so lighter wall thickness works. With this I would lean towards the heavier wall material. If you were to have structure on top of the frame rails, like a roll cage in front and maybe a cage around motor area, then maybe lighter would work. Cages would limit twist.The other thing I am considering is which box tubing for the frame. 2x4x 1/8 wall is 4.75lbs per foot. 2x4x 3/16 is 6.88 lbs per foot. I have not measured yet but just a guestimate is 40 feet total including cross members. Might end up being a little more. That is 275 lbs vs 190 lbs or 85 lbs difference. Does not sound like a lot but would like to keep it as light as possible. Plus the roll cage and other gussets throughout this thing will get some beef. My gut is telling me 3/16 but I would like to get some more opinions.
Certainly some very good points. Here is some more info. At the adapters above the cradle it is 26 inches wide. (approx). The interior dimension running along the inside of the unibody frame rails is 33". I will run the box along the existing unibody frame rails. Weld it top and bottom. So there will be lot of strength there. The 3 crossmembers in green get removed. That is where the engine and trans sit. He has this designed for 6 bolts going horizontally through the box tubing which bolts the adapters on. Shown in yellow I will be installing two more bolts vertical. All 8 bolts will have steel sleeves welded in so it can't try crush the box tube. It is a pretty decent angle to make the pieces dropping down from the top of the cradle to the pieces running along the frame. I think this is the key spot that needs a lot of strength. And where I question if 1/8 is strong enough. Those angled pieces will be tricky to make and get the angles right. Not sure yet how to do that. Then shown in blue will be the roll bar coming down from the top of the cab. That will tie in to the cage inside. I think even with 1/8 wall it would be very strong. One guy in my shop even suggested welding plate to wrap around the unibody rails to the new rails vs just welds. One of my other guys said he did not think it is necessary.So imo the rectangle tube will only deflect energy in two directions. Given the hp you wish to run my concern would be limiting the twist to the frame. With our sand cars and round tube, energy is deflected in all directions so lighter wall thickness works. With this I would lean towards the heavier wall material. If you were to have structure on top of the frame rails, like a roll cage in front and maybe a cage around motor area, then maybe lighter would work. Cages would limit twist.
I had to repair a hotrod truck once where the hp twisted the frame.
That cage will help reduce the chance of twisting a lot. Maybe some type of ladder construction, low, maybe 6 to 8 inches above main rails from rear end to cage. Help tie rear area to the upper support of the cage.Certainly some very good points. Here is some more info. At the adapters above the cradle it is 26 inches wide. (approx). The interior dimension running along the inside of the unibody frame rails is 33". I will run the box along the existing unibody frame rails. Weld it top and bottom. So there will be lot of strength there. The 3 crossmembers in green get removed. That is where the engine and trans sit. He has this designed for 6 bolts going horizontally through the box tubing which bolts the adapters on. Shown in yellow I will be installing two more bolts vertical. All 8 bolts will have steel sleeves welded in so it can't try crush the box tube. It is a pretty decent angle to make the pieces dropping down from the top of the cradle to the pieces running along the frame. I think this is the key spot that needs a lot of strength. And where I question if 1/8 is strong enough. Those angled pieces will be tricky to make and get the angles right. Not sure yet how to do that. Then shown in blue will be the roll bar coming down from the top of the cab. That will tie in to the cage inside. I think even with 1/8 wall it would be very strong. One guy in my shop even suggested welding plate to wrap around the unibody rails to the new rails vs just welds. One of my other guys said he did not think it is necessary.
Yes, That has been the plan all along.If you're going to cage it go .120 wall.
I was speaking of the rectangle tube wall size, sorry..Yes, That has been the plan all along.
Oh gotcha.I was speaking of the rectangle tube wall size, sorry..
You will be able to lift the front if you need to turn sharper say in a parking lot. I think the 4" will be fine for the street.Drove my red car around the block with 4" of turnout. Turns plenty sharp and I think it will be fine. That steering stock at 5 3/8 full lock is very sharp. Could see needing it if the back end is coming around and you need that much angle to turn back the opposite way. Is what it is. I am tucking the tires in by 4". Compromise between function and how it looks.
