- Thread starter
- #241
onanysunday
- May 7, 2021
- 3,504
- 3,326
??Never-ending rhat noise, send that out to a shop with a cnc and have them knock them out...
32 sleeves to cut, drill and tap.... nevermind that noise..... get someone to do them on a cnc.
OK Gotcha. Cut them off in the band saw and then clean up in the belt sander. Not even skimming them in the lathe. Saw gets them plenty close for this. Then drill the box in the mill. Use a die grinder and small burr to clean the last little bit so the tubing slides in. And last weld them in. CNC would not help unfortunately. Just have to do the work and grind it out. The bolt goes through the sleeves so at least they don't need tapped.32 sleeves to cut, drill and tap.... nevermind that noise..... get someone to do them on a cnc.
You might be right. https://gearone-manufacturing.myshopify.com/products/2-5-power-rack But how do I get the tie rod intersection points out to 23 1/2 or lets say roughly 12" from center on each side?Gear one is having a sale.... just sayin... LOL
I think this distance will still be a lot more than 7". Pinion access would run into the cradle.The 2001-05 Civic rack is center steer and has a decent pinion angle.
https://www.amazon.com/Detroit-Axle-Complete-2001-2005-EXCLUDING/dp/B07TYNY4TJ
It's amazon. Buy it, measure it, return it....I think this distance will still be a lot more than 7". Pinion access would run into the cradle.
