Dylanshaffer
- May 7, 2021
- 78
- 91
Had a couple blowouts on the toy hauler this weekend so I’m going to get all new tires. Mine are about 5 years old and looking pretty rough. What tires are you guys running that seem to be holding up well?
How was the side wall cracking on your XPS tires. I am running the same and did on my last trailer. Im due for a new set of 6. Age not miles as usual. I have some decent cracking going on. Trailer tows to G in October then tows back to OC in April. Only real miles they get.I am and always have been a Michelin XPS Rib guy. Just put a new set on the toy hauler, have never had a blowout, separation or other failure in 11 years of running them. They're expensive (like nothing else in this hobby is...), but I feel I have enough going on when I'm loaded and towing that I don't need to worry about tires making the trip. The ones I replaced were 5 years old - that's as long as I go regardless of tread depth.
the Super C is usually 19 or 21" - It really makes a difference . On one of my C Class I did the 19" conversion and I towed a heavy 2 car 26' ft trailer for 4 years with zero issues and never felt like had to worryI have Hercules tires on my Super C. They are a little over 5 years old and I’ve put about 15k on them. So far, no issues (knock wood).
Ill have to double-check but pretty sure mine are the 19.5” . I use to tow a 24’ enclosed and now tow a 32’ enclosed. So I’m pushing mine pretty close to the max. My 32’ trailer loaded is close to 10k which is right at my tow capacity. The Hercules tires are 110psi max, I usually run them right about 100 - 102 psi.the Super C is usually 19 or 21" - It really makes a difference . On one of my C Class I did the 19" conversion and I towed a heavy 2 car 26' ft trailer for 4 years with zero issues and never felt like had to worry
Yeah I meant 19.5 - we just call them 19's (lazy) My trailer was 8500, 10K might be pushing it if you tend to load down the Coach. When I towed the Big Trailer I made sure Not to overload the coachIll have to double-check but pretty sure mine are the 19.5” . I use to tow a 24’ enclosed and now tow a 32’ enclosed. So I’m pushing mine pretty close to the max. My 32’ trailer loaded is close to 10k which is right at my tow capacity. The Hercules tires are 110psi max, I usually run them right about 100 - 102 psi.
I run Sailun on my 48ft WW Full Throttle and I already bought some for my stacker that’s coming soon.Google the Sailun, it is a amazing tire I dont think i have ever seen a bad review on them
