Turbo_Manx_Maniac
- 125
Went to Borrego last weekend, car was running fine. On Sat I let my brother drive the car, we ended up at Rams Hill for a beer. When we went to leave, the car wouldn't start. It would turn over about a revolution and a half and sort of lock up, like it had hydraulically locked. It just kept doing this with no signs of firing up. I tried to bump start it and it started popping like from what seemed like 1 cylinder. I suspected the timing was way off.
Skip to tonight, I removed the belt covers and discovered the crank timing mark was about 3 teeth counter clockwise from the mark with all 4 cams perfectly aligned. The cams did not slip, just the crank.
I pulled the belt and inspected the crank gear and it looks new, no bent or worn teeth. I clean the outer covers yearly and blow out whatever I can reach. Tensioner seems good as well as the belt and idlers. Only thing I can think of is that some oil or grease got on the belt and made it slippery?
So now I am wondering what I should do. Clean it all and put on a new timing belt?
Gates blue belt, Subaru belt?
Hate to call Outfront for this, they gotta be busy on more important stuff.
Sucks we lost all the Subaru info.
The motor is a quad cam 2.5, gt28 turbo at 10 psi with meth injection. It's a JDM from OutFront I got about 10 years ago. It's gonna need some attention in the off season, it's burning a quart of oil every 2 to 3 trips and has about 10-15% leak down.
