Fullthrottleguy
Site Sponsor
- 1,456
You might already know all this, but ...just a suggestion from someone that has done dozens of SC cars - use dual bearing idlers whenever you can - you will have a better experience overall - and replace the plastic idler with a dual bearing Aluminum pulley - I have "melted" those plastic pulleys on SC cars pretty quicklyLOL. Thanks!!!! I learned from a buddy to add the extra idler and use the HD Tensioner.
I am going to have Alex add some supports from the water pump to the head.
Same buddy that recommended the extra idler broke a water pump at the Tensioner mounts. Once he added the brackets, no more issues.
Its amazing how much the belt will "whip" when you get on and off the gas - the tensioner has to be a fast reacting tensioner as well (which you seem to have) even with the 2300 resistance of the SC speeding up and slowly down on the belt is a lot even with the new twisted rotor design . the 2300 is 2.3L per revolution vs 1.85L on the MP112 the belt will stretch at least 1/2" in the first 30 minutes If you can try to after stretch keep the tension sitting at idle at the center of the travel - thats the best practice most of us use
By The Way the 2300 is a really nice upgrade - you will love the low speed performance if its a 5th gen rotor design they make great power
