J Alper
Site Sponsor
- Apr 30, 2021
- 2,023
- 1,757
what i meant about dentition was pre ignition like you would hear a ping or light wrap under load. it causes very high cylinder pressures and could lift the head among other bad stuff cracked ring lands melted piston just depends on how bad it happens. being boosted adds to the stress on the cylinder sealing. btw mcdowell is a great choice and good luck im hoping to make it out around the 17th thru newyears
These guys are spot on, ^^^Sometimes minor detonation will just eat the head gasket out from between the block and head, eventually exposing the water jacket.
If any signs of lean running/detonation, might be worth making sure the rings didn’t lose tension
the piston will look like 1/8 round circles everywhere, cut the plug down to the base if it looks like you put some black pepper spots, or a plug is closed off, and of course a broken piston gland then it might have detonated, typically head gasket does not go out unless the motor ran out of water or had a huge air pocket with a out of control temp gauge with maybe a radiator boil over, Yes we do see them in vehicles that have been on the road with a water leak and no coolant, so you get a rust or pure water eating the gasket, can you pull up the max timing in the ECM, another road to look at,
