I'm kinda surprised that an "anti seize" type compound is used/recommended for CVs Even though it's called a lubricant, it's designed to be used in applications that don't really have movement. It has solids in it that keep mating surfaces from bonding. Like a bolt that is stationary, but you will not want it to gall to the other surface during install/removal. Slow actions.
Traditional anti-seize is a big no-no in areas a lot of movement or vibration cycles, like a splined shaft driven implement. The solid properties of the anti-seize actually be some more like an abrasive. Grinding the mating surfaces away. This is called Fretting. You would never want to put anti-seize on the splines of a drive shaft. There are specific lubricants for applications like this. Anti-fretting compounds. When a failure is found in these applications, typically splined, the disassembled pieces look like they are/were greased, but may have become wet as the "grease" looks rusted. This is fretting wear or sometimes called fretting corrosion. The orange color is a telltale sign of fretting. This happens because the wrong lube (or no lube) was used, like anti-seize.
