chevy1925
- Aug 5, 2021
- 36
- 21
engine load should read negative at idle based on the setting he has to show engine load. what his is showing is the correct load for the idle. Its reading in PSIG and in comparion to his manual gauge, its spot on. gauge is read in in/hg, conversion shows the 21in/hg is equal to the -10ish PSIG
the issue is elsewhere. if the stock ecu fixes this and the current aem can be ran in your car without issue, i would bet its a pin out problem at the ecm into the harness. I take it you havent tried to run his stock computer in your buggy, have you?
