LtPyro
- May 6, 2021
- 182
- 69
Ok so you can't get all the info from the title. But here is the short version:
My father and I are both running Honda 3.5 engines and recently added turbos. We both bought AEM ECUs. I have installed the same tune on both cars, essentially the stock tune modified just a little (lower rev limit, lower MAP sensor BAR pressure...). My car runs perfectly fine on the AEM with no issues. My fathers car however floods itself. On the stock ECU he has no issues. After installing the AEM and turning the ignition on (but not starting the engine) one or two cylinders (guessing on the number) flood themselves as if the injectors are being held open.
I took his AEM and installed it into my car and it runs perfectly fine, no issues. Just doing this leads me to believe the issue is with his wiring or engine.
I'll be heading out to Havasu this weekend to help him troubleshoot it.
Any ideas of what might be the issue or things to check would be helpful.
