- Thread starter
- #941
onanysunday
- May 7, 2021
- 3,925
- 3,548
Well, they only control the truck and your safety. Weld away!Call me crazy but I had to add four more rosette welds for a total of eight. Plus welded all the way around the edge. I also need some sort of 6-point flat to put a wrench on it to tighten each tie rod. I don't really want to cut into this tube and make it any thinner anywhere. Not quite sure what to do with that.
Get a nut that almost fits around the OD of the tube. Drill out the center to slightly larger than the OD of the tube and weld it on. Gives you nice flats to work with. Perfect for practicing your TIG welding.Call me crazy but I had to add four more rosette welds for a total of eight. Plus welded all the way around the edge. I also need some sort of 6-point flat to put a wrench on it to tighten each tie rod. I don't really want to cut into this tube and make it any thinner anywhere. Not quite sure what to do with that.
