- Thread starter
- #781
onanysunday
- May 6, 2021
- 3,964
- 3,580
That SHO is cool looking. I have actually been looking at the B&M pro ratchet vs the Winters. A little more money at $409. Comes with a 5' cable which I will need longer. I assume longer cables are available. Although the budget has been blown out of the water on this project I still do look at certain things and ask if I need to really pay more for an item. Is the SHO a ratchet style shifter like the B&M? $690 for the ratchet bitch which is a little pricey.I'd love to see something other then a winters, they are so boring and clunky.....
I got a Ratchet B!tch Shifter for my project. Ease of standard selection with the bang shift option for sporty fun.
https://www.kilduffmachine.com/
Shoot even the SHO shifter is better to me
https://sandhollowoffroad.com/product/speed-shifter/
Certainly very cool. But $283 versus $690 is a lot of change.That's why I got what I did. I wanted both a standard style just put in D thru the gates (3 for my TH400) and go trans does what it should shifts normal based on load.
but...... with the +/- bump action of a ratchet for when ya want to hold and bump shift 1-2-3
Hmmm. That is pretty cool. I like the bigger handle versus around knob as well.FWIW, I used a B&M mega shifter on 3 projects & loved it. 2 were 3 speed & one was a 700R4. none manual VB Trans, but were shifted manually on "spirited drives".
I loved the thing. took a bit to get it adjusted right (especially on the 700R4), but once I got it there & locked it down, it was golden.
The top flange is the fuel level sender which is correct. The small dash 6 fitting up top is going to be a second overflow breather valve. The pump itself has an overflow breather but it sits so much lower in the tank on the step. The tube on the top is where my flip over gas cap will connect to with a short piece of rubber hose.. That will be my next project which will be a piece of 18 gauge steel that gets built and covers the top of the tank. That flip over gas cap will attach to that panel that I build and has a gasket on both sides to seal it all up. I'm also going to have that flip over speedway cap powder coated black so it will pop against the bronze panel. I also added drain at the bottom of the tank since I can't go down through the gas cap and get all the way to the bottom. That front section of the tank was baffled and only has a whole bunch of small holes to allow the gas between the two sections. Certainly want to be able to drain the tank and make it light enough if I have to pull it out. I just used a very small dash 4 on that drain. Easy to pull the cap off and shove a piece of 3/8 hose over the fitting and let it drain into a fuel jug.What is the largest flange and the largest tube on the very top? I would assume one is the fill (the tube?)
The flange the fuel level sender?
