matt86m
- May 6, 2021
- 1,146
- 1,322
Had a bit of a 'scare' with my truck last week.
Driving to Mesa, AZ, Im 35 miles from a buddy's house when the motor died on me in heavy traffic and wouldn't start. AAA to the rescue.
History: 2013 Chevy Duramax, 57,000 miles, VERY well taken care of (except by me as you will see :lol: ) Had a slight 'hard' start after it sat for a couple weeks, didn't think anything of it. Started fine after that. Loaded it up and got to Tom Wells Rd in AZ and had to crank it for 30 seconds or more before it started. While driving 70-75 had a couple slight hesitations in the throttle, got into stop n go traffic and it died. Right before it died I did get a "change fuel filter" warning on the dash then it disappeared.
Mistakes: I didn't check the dash info to see how much fuel filter life was left before leaving! Had 7000 miles on it since the last change. I owned an '07 Dually/Duramax for 9 years and always changed the fuel filter every other oil change (5000 mile intervals)
While we were in Texas hunting, one of Joe's guys changed the fuel filter but couldn't get it to stay primed. He just went thru the dreaded CP3/CP4 destruction and it cost him over $10,000 to fix the fuel system.
Turns out he didn't get ALL the air out of the filter - didn't prime it enough. When we got home another guy came over with a scanner, NO codes and he primed the filter as I turned the key. It took A LONG time and 4-5 times before it stayed running. Let the truck idle for over an hour, started it several times and all was good. Was able to drive home with no problems.
Are you still reading?! :lol:
As I was passenger for an 11 hour ride I was able to read nightmare story after story of CP4 (that's what I have) failures.
SO,,,,my question, what have you done to 'prevent' this from happening?
I have read about lift pumps - not cheap but a HELL of a lot cheaper than the thing scattering metal thru the fuel system.
What else is there to help prevent it from happening?
:cheers:
:cheers:
