Kraut_n_Rice
Site Sponsor
- May 9, 2021
- 3,500
- 2,762
I used the bead sealer last season and it did not fix the issue.RTV the bead lock?
I was a stayflo fan, but 2 applications of that leaking out sent me to try something new.I took the Berryman’s out of my paddles. I got tired of the red stains and found Stalo starch seals much better.
I am winning my tire war, but slowly. I am only using Sta-flo. I did the Berymans at a time in the past and really didn't like it. I probable at this point have between 1/2 and 3/4 bottle in one tire.I was a stayflo fan, but 2 applications of that leaking out sent me to try something new.
How much staflo are you using? I put a full bottle in each one of my paddlesI was a stayflo fan, but 2 applications of that leaking out sent me to try something new.
When they were not leaking down every day I had been using 20 Oz/paddle & 12 Oz/front (of starch). When I broke the wheels down there seemed to be LOTS of starch rolling around inside each of the tires.How much staflo are you using? I put a full bottle in each one of my paddles
Ive never heard of this one. "worlds best Tyre sealant" is a pretty bold claim...Berrymans old formula worked great. The new formula, not so much. I’m going to try some Monster Seal tire sealant and see how that works.
Kinda like this??? LOL.I switched from Berrymans to Liquitube at the recommendation of Fullerton Sand Tire several years ago. What I found was that the Liquitube worked well at sealing punctures because the mix contains fibers which do a good job at plugging the hole. What it didn’t do well was seal the pinhole leaks around the bead lock and bead. Supposedly Monster Seal has the ability to do both. The original Berrymans was the consistency of a watered down paste that would fill up small holes and congeal. New stuff just leaks out of the tire around the bead like water.
