Bobalos
- 5,344
I have STU sand blaster 33x15s on my buggy now. This is what I had on the buggy previously as well.
I did have starch in the previous set. I could go the entire season and only have to air up and down to compensate for wet or dry sand.
I broke a wheel some time ago and bought a set of "douglas" wheels from joe fab and that is what running now.
I have tried nothing, starch and bead sealer and I can't get them to hold air beyond a single weekend. The last 2 trips the drivers tire would not hold for a day.
I did the soap on the bead trick and nothing stands out as the culprit. They just leak from everywhere... LOL
The out side of the tire that goes on the beadlock looks ok, but the inside that goes on the "normal " bead looks like the bead is crumbling. Not smooth at all...
I'm tempted to swap the tires from side to side so the beadlock side is now sealing on the bead and vice versa.
Also the inside bead of the wheel looks more rough than I would think they should to keep air in. But I don't know what it should look like... any thoughts on taking some 220 grit to it and smoothing out that surface?
Or maybe i should juat goop the ship out of each bead with the bead sealer and hope for the best?
Anyone have any thoughts?
