Desert dynamics questions
Just to add to the confusion, my last car was a DD sand car chassis.  1.5" all chromoly but I added the "prerunner or dual sport" front arms and 2" hollow spindles.  So I wouldn't trust arms and or spindles as the deciding factor.  To the unknowing, I could have easily thrown dirt tires on it and sold it as a different chassis.  All of the above info is great.  It's basically the dimensions and material of the chassis itself that is important
kind of, but not really,  the Rear Cage is completely different,
I was thinking the rear cage changed after like 07 or 09.  Mine was a 2006.  All of the more recent cars have the newer rear cage. Who knows
All the Sand cars have the same cage, they never changed it,
hey jason, do you have the info on the updated front geometry dave did before he went mia? i know you did it to your old car, but alas.. all that info is now gone form the site 🤬
One of the guys in our group bought a DD car with Boxed arms  - of who knows which model - but the geometry was messed up - the car rubbed everywhere and handled like crap, it was bear in the dunes  - Kevin McMullen straightened the car out  and now he says its a dream to drive  dunes and desert
how was it messed up?
I did not measure the car, but the upper and lower arms had the UNI balls too close to the arm (arm was too wide too close to the Uniball) and when he turned the Brake Caliper would scrape up and down on the arm and  "catch" on the arm - it ripped one of the calipers off in the desert.  If he turned hard the other way the tires would rub.  If you cycled the front wheels up and down without the shocks,  the steering wheel would move back and forth - which told me the tie rods and arms were not inline. It also had pretty bad bump steer
I thought it was just wrong wheel offset when he said it was "rubbing" until I looked at what was rubbing.  I looked for good pics  but can't find them.
Only pics  I could find were from the video
He brought it to Kevin McMullen and Kevin said "someone" messed with the car possibly trying to straighten it out  - he named a GD member, but I won't name him. But Kevin said he had the Jigs and remade the Arms moved the rack, and fixed the issues  - it was not cheap but it was safe to drive after that
It was the only DD with lower Boxed "J: arms  I ever saw so I don't know it it was from Dave like that of not
My car has boxed "J arms" but no issue(s) that you mentioned above. Not sure if the arms was original to my buggy or not. I'm the the original owner.
Your car has always had those arms. It was in my camp 10+ years ago. One of my favorite DDs
Here it is in 2016 I believe
Does anyone know who makes j arms for 06 dd 1 1/2 car problem .im having is tires hit lower arm, so i dont get full steering also running a howe rack hope info was enough
Run a small wheel spacer like 3/8" - 1/2" thick
depending on wheel offset and tire diameter  they will hit what ever arms are the car. there was usually a stop placed on the steering rack rams to limit the turning depending on who built the car.
