I did not measure the car, but the upper and lower arms had the UNI balls too close to the arm (arm was too wide too close to the Uniball) and when he turned the Brake Caliper would scrape up and down on the arm and "catch" on the arm - it ripped one of the calipers off in the desert. If he turned hard the other way the tires would rub. If you cycled the front wheels up and down without the shocks, the steering wheel would move back and forth - which told me the tie rods and arms were not inline. It also had pretty bad bump steer
I thought it was just wrong wheel offset when he said it was "rubbing" until I looked at what was rubbing. I looked for good pics but can't find them.
Only pics I could find were from the video
He brought it to Kevin McMullen and Kevin said "someone" messed with the car possibly trying to straighten it out - he named a GD member, but I won't name him. But Kevin said he had the Jigs and remade the Arms moved the rack, and fixed the issues - it was not cheap but it was safe to drive after that
It was the only DD with lower Boxed "J: arms I ever saw so I don't know it it was from Dave like that of not
