EmpirE231
- Aug 12, 2021
- 686
- 536
Just popped in all new Gear One CV's in my car and running their new podium lubricants CV grease to see how it does, I have heard good things about this new grease. @parker@gearone
So KY Jelly is the best stuff.Like many things in life: depends on the stroke length...![]()
Naw hoss, Astroglide.So KY Jelly is the best stuff.![]()
Am i reading this correctly, i feel the clear winner is Permalube.On my old VW Buggy I used the Lucas green & had no issues.
On my PSD I started out with the Cat Extreme Application Desert for 2 seasons, then changed to Certified Premalube Xtreme. not sure what Im going to do this year....
In our Group we all do it differently:
Marv: Ricochette
Swepco 101
934
2D
Scott: 06 PSD
Belray MolyLube
934
PBS Seq
Doug: Sand Limo
Swepco/Belray
934
2D
Bob: 15 PSD
Certified Premalube
930
2D
I have this chart in an excel format, but the new forum will not allow me to upload it.
Hot dam dude.Well… I hope this debate can finally end— been working on this grease for almost 2 years now.
I’ve been lucky to work with some seriously smart people — real lubricant chemists, not just racers with opinions. We tested everything on the market: 4-ball weld test, temperature resistance, you name it. And then we put it in the cars that matter — everything from average LS cars to some of the fastest cars in Glamis.
On top of that, Kevin and Connor McMullen have been thrashing it in their 5000 lb prerunner in the desert — real-world abuse in high-speed, high-load environments. It’s been through seven revisions before we even considered releasing it.
Some quick nerd facts for the skeptics:
- This grease weighs 11.04 lbs per gallon
(for reference, Bel-Ray is 10.05 lbs)- Uses a synthetic thickener, and is packed with molybdenum and a high load of graphite
- Temperature rating: -184°C to 399°C
- 4-ball EP weld: 500kg
This stuff is dense, and making something like this isn’t cheap. We didn’t cut corners. No repurposed blends. No bean counters. Just the best formula we could make — specifically for 930 and 934 CV joints.
We only ran 2,000 tubes on the first batch. It’s not some mass-produced general-purpose grease — it’s purpose-built, race-tested, and podium-proven.
I will do my best to post updates here, we have more products in development. But feel free to follow the Instagram.
Where do we order mang?Well… I hope this debate can finally end— been working on this grease for almost 2 years now.
Where do we order mang?![]()
gearone-manufacturing.myshopify.com
Recommend two tubes for 4 CV's? I want to get some ordered while you have it in stock.![]()
PODIUM LUBRICANTS CV GREASE
Podium Lubricants CV GreaseDeveloped exclusively for use in 930 and 934 CV joints, Podium Lubricants CV Grease is Race Tested and Podium Proven to outperform all other greases on the market. Specifications: Synthetic thickener Infused with MoS₂ (molybdenum disulfide) and graphite solids Useful...gearone-manufacturing.myshopify.com
Podium website should be up shortly with a gd.com discount code. Until then it will be sold through gearone
930 - two tubes for 4 cv jointsRecommend two tubes for 4 CV's? I want to get some ordered while you have it in stock.
You can add podium grease to any other moly grease you already have in your cv joints.Can you add the new Podium grease to other existing grease if you just need to add a pump or two? Or do you have to clean the CV's entirely and start with all Podium grease?
Great! I just ordered two tubes. Thanks!You can add podium grease to any other moly grease you already have in your cv joints.
Thanks for the order! Let me know what you think once you get it.Great! I just ordered two tubes. Thanks!
I just ordered received my 4 tubes of grease to try for the season and there’s not even enough grease in the 4 new tubes to even do my CVs. The tube are only half full which is a little BS but I guess it weighs more. Be aware guys to buy an extra tube if you’re planning to use this stuff.Well… I hope this debate can finally end— been working on this grease for almost 2 years now.
Did you reach out to @parker@gearone ?I just ordered received my 4 tubes of grease to try for the season and there’s not even enough grease in the 4 new tubes to even do my CVs. The tube are only half full which is a little BS but I guess it weighs more. Be aware guys to buy an extra tube if you’re planning to use this stuff.
First off, thank you for trying my new grease — I really appreciate it. I totally understand your frustration with how full the tube is. That was actually the one thing I wasn’t happy with either.I just ordered received my 4 tubes of grease to try for the season and there’s not even enough grease in the 4 new tubes to even do my CVs. The tube are only half full which is a little BS but I guess it weighs more. Be aware guys to buy an extra tube if you’re planning to use this stuff.
