Sausage450r
- 2,471
Who makes a decent generator? I got a “Powerstroke” 8k watt running generator about 14 years ago. It has been great. Powers my whole house when the power is out. We even run the heater and do laundry. Transfer panel it runs off of with a 50 amp plug. Well 30 minutes into this power outage it stuck a valve. I’ve never had a single issue its never failed never had to clean the carb, only replaced the starter battery once in all this time. I want another genny like this one. I cant seem to find the same unit new.
When this generator failed; i found the lone 8k watt dewalt generator for sale new in all of san diego and rushed to buy it ($1k). Got it home; set it up. The “electric start generator doesnt have an electric starter, great we get to pull start a 400cc 4 stroke. Ran it for 2 hrs, ran well and powered everything well. Shut it off for the night. Next morning wouldnt start. Has fuel, has spark, wont run. No replacement in the county to buy. Home depot said i cant return it if i take it apart. At this point after pulling it 5,000 times i no longer want anything but electric start. Reading online seems all these new CARB compliant generators with CO2 detectors fail. The chips on the co2 board cant take all the vibration.
What is out there “new” that you have had good luck with. I will go out of state to buy. No budget. Only needs are 8k watt (running) minimum. Gas/propane, would prefer portable vs stand alone
