AndyORRN
- Nov 11, 2023
- 38
- 36
I've got my head a few times in this processThis car is full-on bonkers!!!
I've got a pretty nasty Porsche 911 and a beast of a 1968 Dodge Charger R/T and I love snapping necks when I am out just running errands in either. I know you've got to love snapping necks in this monster. Looks and a beast motor to back up the aesthetics = perfect package.I've got my head a few times in this process
Yeah, had that discussion with Grey Area, the manufacturer. They have been great to deal with even though I had a leak due to a pinched o ring on their assembly. They sent me a seal kit over the holiday week so I could work on this and have parts on hand. I have a caliper off and apart. No swollen o rings or issues there. I will pop out the pistons while is off and give it a good check over.Not saying this is your issue but I had a similar problem once. Guy at Kartek gave me power steering fluid instead of brake fluid once. I didn’t realize it until after I had the brakes all bled. I drained it and blew everything out and used brake fluid. First trip out cruising around about 20 minutes into driving the brakes locked up. I cracked a bleeder and hot fluid sprayed and smoked its way out. Drove with no brakes for the rest of that weekend. Fast forward to next season I flushed and bled the brakes again. Every so often I would walk in the garage and see the brake lights would be on. Usually on a hot day. But they never locked up on their own again. Moral of the story is weird stuff happens with brakes if the wrong fluid is used.
Considered the turning brake as well. IMO if and when I moved it opposite or just worked it back and forth it might release the pressure. That never helped. Also, I cracked the brake lines at all 4 corners. At the masters and also the bleeders at the rear calipers and the car was still locked down.Do you have turning brakes? Maybe piston isn’t returning fully keeping slight pressure on the caliper. Pads heat up and expand, locking up a wheel. If issue is with both wheels than maybe a faulty residual valve?
Super soft material after researching the brake pad manufacturer. But... It's what Funco used and supplied to me by Funco.Maybe something is going on with the brake pad material. Have you tried changing the pads?
Flushing all of it tomorrow. Need to check all the boxes.Mystery for sure. Caliper is parallel to rotor? No kinked hard line or hose? Have you tried flushing out your brake lines to remove any possible debris or obstruction?
